Aero port box design
betweenmatt
You determine it by cone area, xmax and tuning frequency.
This is a good quick calculator.
http://www.carstereo.com/help/Articles.cfm?id=31
I see, why does it give a minimum of 7.5" aero for a 12" driver with a 35mm xmax
Because of the amount of air being moved. The port per cube rule came along when speakers had a much much lower Xmax.
Xmax doesnt change the calculation much... How many people have you seen run 50 sq inches of port on a single 12" driver? the calculator doesnt seem right to me
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
It doesn't mean you will get better SPL, it will eliminate chaffing and vastly improve your sound reproduction quality.
If your building a box to listen to, not solely for the lanes then follow the calculator, if you are for the lanes only then you should already know you need to try multiple variations for the highest acoustical output.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
It's science and proven fact, you use the same fundamental calculations when building engines or instruments or aerospace equipment.
The calculator is designed specifically for audio and follows the same equations laid out by the man who even today we use his parameters to determine the properties of speakers.
Why are you defending the calculator? if you have ever tweaked with a box before you would know that those numbers it gives are completely wrong for any daily application.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
The best method I've found for determining port area is to plug all the info you have into something like WinISD or TermPro and see what port velocity you get for the power you are running.
The port calculator listed above or the port per cube method both operate based on some assumptions. This doesn't make them good or bad, they are just starting points and are limited in there usefulness.
Also I'd like to squash a misconception I saw earlier in theis thread. Port size should have no effect on the peakyness or flatness of the box. Box size and tuning does. The only time port size is going to effect it is if the ports are grossly undersized and are killing output around tuning.
Builds:
wow this thread got pretty hot lol.... So I'm running 4 10" alpine type e's, which have a 10mm xmax. According to the calculator I need 8" diameter port with just under 17" of length for one port. My box will be 5.5 cubes with the port mostly internal. I'm tuning to 32 hertz. Is this a solid plan?
edit:
and according to winisd with 5.5 cubes and 8 inch diameter i need 17.72 inches long. Is that more accurate than the website calculator?
Me, I do. When you have a sub with a throw of 34MM xmax, you NEED port to make it function as intended. Port per cube theory need to burn a fiery death, like now.
  • Who's Online   0 Members, 0 Anonymous, 9689 Guests (See full list)
