NEW TO THE SITE. I HAVE WATCHED SMD FOR YEARS AND ABSOLUTELY BLOWN AWAY. NEW PROJECT...2006 HHR ALL STOCK. GOT A RIDICULOUS DEAL ON SOME PIONEER GEAR....NOT THE GREATEST BUT FITS MY STARTER BUDGET. MY QUESTION IS THIS...I HAVE THE Pioneer AVH-270BT 6.2" Double-DIN DVD Receiver . I HAVE REPLACED THE FACTORY 6 1/2 DOOR SPEAKERS (4) WITH THE Pioneer Ts-a1685r 6.5" 4-Way Speakers. THE PLAN IS TO RUN THE FRONT RCA TO A Pioneer GM-A4604 480-Watt 4-Channel Amp AND THEN RUN THE NEW SPEAKER WIRE TO EACH DOOR. I ALSO PLAN TO RUN A PAIR OF Pioneer GM-A5602 2-Channel Bridgeable Amplifiers with 900 Watts Max Power and Bass Boost Control. I PLAN ON RUNNING 1 OF THESE AMPS PER SUB WHICH ARE THE Pioneer TS-W3003D4 12" 2,000-Watt Champion Pro Subwoofer. THE PROBLEM I HAVE IS THERE IS ONLY ONE REAR RCA BUT 2 AMPS. CAN I RUN THE ONE RCA CABLE FROM THE DECK TO THE REAR AND THEN USE A SPLITTER OR WILL I ROB POWER FROM SOMEWHERE AND PAY FOR IT? SORRY FOR THE MESSY POST...HAD TO USE CUT AND PASTE. THANKS.
MICHAEL
Doesn't Scott have or made a cock block (can't remember if that's what it called) that has one RCA input with multiple outputs?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
If you have not purchased the amps yet, then look for ones with input and output RCA's so you can daisy chain them with no loss in output from the H/U.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
