What is everyone using to screw subs in??
Pioneerchuck
Spax #14 multimaterial construction
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
There are lots of different opinions on this topic. I've been trying all kinds of different stuff and I'm yet to settle on one thing.
I know lots of folks use the big spax or deck screws, and they certainly work. My problem with them is they are generally flat head, which means the area of the screw that contacts the mounting flange is tapered resulting in a very small contact point. That just rubs me the wrong way so I prefer fasteners with a flat contact area. So I stick with round head, pan head, and socket head screws.
If you want to screw directly into the wood these work well, though I wish they were a littler larger and longer:
http://www.parts-express.com/m5-x-30mm-cap-head-wood-screws-black-100-pcs--081-312
If you want to use a socked head cap screw and some kind of threaded insert these are my favorite:
http://www.parts-express.com/parts-express-1-4-20-barbed-body-insert-nuts-50-pcs--081-1096
Builds:
By far I've used course thread drywall screws and haven't had any issues. But then again, by far I haven't ran a setup over 1,000 rms. So I can vouch for them in a lower power setup, they'll work fine.
I prefer bolts/t-nuts because when you have to remove and replace them they hold up better than a screw going through MDF. Plus they dont strip as easily as screws do.
  • 1 month later...
Use 1/4-20 size hardware, t-nuts are pretty standard, for the bolts I'd suggest socket head cap screws.
Builds:
