How bad/good is polypropylene?
Is a woofer cone composed of polypropylene a good or bad material? I know it is pretty common, but how does it fair compared to paper or other material types?
Materials doesn't effect the sound of the woofer, if your judging based off of that route. Polypropylene is a sturdy material, so I don't see it being a bad material for a subwoofer cone.
Thanks man!
You sure about that? I find it hard to believe that manufacturers use about 50 different types of materials for cones if it doesn't matter what they're made of and it wouldn't effect the sound.
Maybe it doesn't matter as MUCH in a sub as a woofer thats made to produce more of the freq. spectrum.
Different companies use different materials, because they may prefer a certain material over another because they believe that the strength of that particular material is efficient for the sub that their making. Material still doesn't change the tone or sound of the woofer, in the low frequency spectrum which a sub produces.
I'm confused, are you saying that given two subs, only difference being the cone material, that both will sound identical?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Let me explain in a little more detail. You have a brand that produces a line of subs. Their A line of subs has a certain basket, motors, leads, spiders, cooling etc etc and then they have a choice of which cone material they want to run. Lets say they want polypropylene for Line A. Lets say Line B had different baskets, motors, leads, spiders, cooling etc etc and they want pressed paper cones for that line. Will both lines sound different? Absolutely. But lets say with Line A's specs vs The polypropylene cone vs the pressed paper cone within the same line, you would not notice a tonal difference at all. Same with Line B.
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
