kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Some more lighting Some reverse lights For fear of taking the lights on with a trailer, mounted the lights on the outside of the bumper Worked out nicely i'd say lights to house is about 125 ft, reasonable DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Wasn't bright enough with just the pods, so the 20" bar needed a home on the rear as well Measured out Bushing for the wiring Sealed in DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Permanent wiring solution Pods and rear facing bar are on dedicated switches to use in other fashions then just reverse Harnesses to control the rear lights DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
MADVIBES Posted January 2, 2016 Report Posted January 2, 2016 The bolts holding your plexi glass to your box are kinda chunky, I think it looks sick! DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Quick picture of lights being used for night loading Front bar time Pansy 5/16" hardware is not gonna work for this, 3/8" is much better mounts Third harness DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 New idler and tensioner pulley install Never let go of a tool with tension on it, no matter how "secured" you made it Time for the alternator DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 OEM adaptation, gotta love it when your alternator builder knows what they're doing A bit nicer looking A bit bigger too Having been told someone else, Berto i believe, has made this casing fit on the 5.0 as well, i knew that i'd be making some modifications to make her fit properly. The new casing is a good inch deeper which would encroach on the valve cover space, which I can't hammer in because of the rockers. 2.5" spacers are needed to lift the alternator up over the valve cover, to which even the spacer leaves 1/8" of space between the casing and the cover, i got lucky lol. This put the alternator in line with the throttle body and covered nearly 2/3s of the intake, custom intake part 2 coming up lol Not gonna need that back mount anymore so sent it back to Singer for some more modification. If anyone is looking for an alternator builder that understands your needs, takes the time to call you and take your calls about mods and upgrades, Mike Singer is your guy. I've tried other builders and i keep coming right back to Singer. DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Factory mounting bolts are a m10 which would work if need be, but with the spacer size and how much i beat on this motor, coupled with the rear mount delete, i wanted to make sure i had enough beef in the front mounts. Decided the only option is to bump it up to a 1/2" threaded rod. She don't fit, more modification needed Gotta modify the vehicle side mount Alot of in between pics i wasn't able to get of the rethread, the headache of the holes being crooked and further modification needed but she's in and functioning D3400 out and D6500 installed with some SHCA terminals and wiring, temporary wiring option until i get amps and batteries sorted in the rear. DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 So, back to that sheet of birch ply.... Some measurements, that only ended up being half useful after some plan changing lol Assembly Station Time to build She wanted her own project to work on, pallet furniture it is, she wanted some side tables for her living room DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
kryptonite Posted January 2, 2016 Author Report Posted January 2, 2016 Special Delivery, wonder what they could be? DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
