tdsa23 Posted February 10, 2015 Report Posted February 10, 2015 I love my Q I say get the Q it leave you room to upgrade amps down the road. XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
kirill007 Posted February 12, 2015 Report Posted February 12, 2015 Fi SSD 12Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mmRms: 1000W Fi Q 12Fs: 34.2 Hz | 33.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.63 | 7.69 Qes: .39 | .39 Qts: .37 | .37 Mms: 249g | 253g Cms: 0.87mm/N | 0.87mm/N Sd: 481cm^2 | 481cm^2 Vas: 28.3 l | 28.3 l Spl: 86.5dB 1W/1m | 86.3dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500WEvery spec in red is different. And you can read the discription with each sub. yeah they are different but not by much. I would think the only one that makes a difference is the xmax. This is just me thinking out loud but if you were deciding between the two the xmax would be the deciding factor depending how you want things to sound. In my case I have 2.8cu ft and an AQ 1200d running a single 12 makes things a little difficult deciding between them I know ill most likely go with the ssd. Im just trying to really understand the two and thier prices. Read the book Loudspeaker design cookbook by Vance Dickason and you'll understand what is important and what isn't. (spoiler: everything is.) Thinking is the root of all problems... You ALWAYS get what you pay for.
BigManAC Posted February 12, 2015 Report Posted February 12, 2015 From what I understand the Q subs are low end subs that move tons of air. If that's what your looking for them go with that. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
