quincyj34 Posted February 7, 2015 Report Posted February 7, 2015 Whats the main difference between the ssd and the Q? Is the Q just beefier?
magillaru Posted February 7, 2015 Report Posted February 7, 2015 Not trying to be a dick but did you look at the specs on their website??? That would be a good place to start. Singer Alternators Team Asshole #anothershittysingerbuild
Miguels Posted February 7, 2015 Report Posted February 7, 2015 the main difference is that both of them are different subs my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
quincyj34 Posted February 7, 2015 Author Report Posted February 7, 2015 I have looked at the specs and they seem almost the same. Just trying to figure out what makes it a $100 more. It has 8mm more xmax and is rated for 500 more watts but that seems to be it. I can see a clear difference in the Bl and the ssd but with Q and ssd on paper they are almost identical.
Miguels Posted February 7, 2015 Report Posted February 7, 2015 totally different subs and you just mentioned the difference they are not identical at all my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
OldsBoomer Posted February 7, 2015 Report Posted February 7, 2015 lets see if I can be more helpful. What are your goals? Equipment list? Vehicle? Space? Those differences that you stated are really big differences, you may not think so just starting out but that all maters. Suburban Coming Soon
kirill007 Posted February 7, 2015 Report Posted February 7, 2015 Fi SSD 12 Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mm Rms: 1000W Fi Q 12 Fs: 34.2 Hz | 33.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.63 | 7.69 Qes: .39 | .39 Qts: .37 | .37 Mms: 249g | 253g Cms: 0.87mm/N | 0.87mm/N Sd: 481cm^2 | 481cm^2 Vas: 28.3 l | 28.3 l Spl: 86.5dB 1W/1m | 86.3dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500W Every spec in red is different. And you can read the discription with each sub. Thinking is the root of all problems... You ALWAYS get what you pay for.
hdorre Posted February 7, 2015 Report Posted February 7, 2015 Fi SSD 12Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mmRms: 1000W Fi Q 12Fs: 34.2 Hz | 33.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.63 | 7.69 Qes: .39 | .39 Qts: .37 | .37 Mms: 249g | 253g Cms: 0.87mm/N | 0.87mm/N Sd: 481cm^2 | 481cm^2 Vas: 28.3 l | 28.3 l Spl: 86.5dB 1W/1m | 86.3dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500WEvery spec in red is different. And you can read the discription with each sub. lol.. so everything but VC resistance and cone area are diff On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
quincyj34 Posted February 10, 2015 Author Report Posted February 10, 2015 Fi SSD 12Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mmRms: 1000W Fi Q 12Fs: 34.2 Hz | 33.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.63 | 7.69 Qes: .39 | .39 Qts: .37 | .37 Mms: 249g | 253g Cms: 0.87mm/N | 0.87mm/N Sd: 481cm^2 | 481cm^2 Vas: 28.3 l | 28.3 l Spl: 86.5dB 1W/1m | 86.3dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500WEvery spec in red is different. And you can read the discription with each sub. yeah they are different but not by much. I would think the only one that makes a difference is the xmax. This is just me thinking out loud but if you were deciding between the two the xmax would be the deciding factor depending how you want things to sound. In my case I have 2.8cu ft and an AQ 1200d running a single 12 makes things a little difficult deciding between them I know ill most likely go with the ssd. Im just trying to really understand the two and thier prices.
Miguels Posted February 10, 2015 Report Posted February 10, 2015 just a bit on the ts specs means a lot.. if you like the lows get the Q my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
