90,000 Watt Daily Build Update
pretty crazy but can them amps produce close to 30k at all?
Pretty sure he said prototype and nobody has tested them as of yet.
I'm pretty sure i read it what i meant to say is, per previous models i don't see them getting close to 30k.
Lol, I knew this was going to come up sooner or later.
To simply put, I really don't care if it does or doesn't put out 30k all day every day, or even close. Even if I only see 20k, that's still 60,000 watts. So what I'm trying to convey is, try not to get so caught up on just wattage itself. If it's 90k, or even just 45k. That's a lot of fucking power. Especially when considering this is my only vehicle.
Tells people not to get caught up in the wattage itself but title of thread starts of with "90,000 watts", makes sense.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
People just wanna hate as usual.
Even if the amps could put out 90k chances of actually seeing full output in the car aren't very good and the same can be said for any amp.
Don't hate because he's got more bank than you.
How much does that battery weigh? Just wandering if they are lighter in weight compared to standard agm. Also its your gear,keep doing your thing! I think its pretty cool someone would spend this much time and money on something not mainstream, and share it with us.
yes much lighter.
im making a 20 ah 300 volt pack and it only weighs 100 lbs. this battery should probably weigh in at around 35-50 lbs total.
Lithium is the future.
tuned in for this build
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
yes much lighter.
Cool! thanks for the info Bump4life! Lighter,stronger,faster definitely sounds like the future.
Can't wait to see how this turns out
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Thanks for such a warm welcome guys. Really does mean a lot to me. If you've ever met me in person for a demo, or anything, you'd know I'm very humble for everything. And there's nothing else I love other than someone else enjoying my system, especially when it's done the way I want it done. I just want to show other people that there are other ways of getting loud. So far, I've done everything untypical of our current community. I run Brazilian, less subs more box, unknown subs, everything. And I'm really fortunate for the sucess I've had so far. Not to say no one else has taken the route I have, but I truly do believe I'm doing this on a large scale, and best of all, I am sharing everything with you guys. So that you too can watch where this road leads to. So again, thank you for all the support!
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Yeah, the 40ah weighs 40 pounds, and the 80ah weighs 80 pounds. I went from about 900-1,000 pounds to 80 pounds for the same power. Another reason for the change and investment. All that weight driving to shows 10 hours away, and using it every day, creates a lot of wear and tare on the vehicle. So I made the change just in time.
6 15" SSA Evils
18 XS Power D3400s
dang, 80 lbs, must be all the hardware inside the case. I was making my estimate off individual cell weights :peepwall:
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 2340 Guests (See full list)
