KO4Life Posted February 18, 2015 Report Posted February 18, 2015 I have never done this myself and I dunno how to do it so I am here asking for help. I have 2 Soundstream TA1.3000.1's and 2 HDC3 15's dual 1ohm subwoofers I am going to wanna run them at .5 each and yes I will have electrical to back them up aswell what do I need to do to run both amplifiers one per sub and will a DD-1 be able to be used to adjust the amps, also does the box need to be different because of 2 amps cause I do know about the right power for a box. Thanks Budget Banging On A Budget..... 99 Civic EX Coupe XS Power/SkyHigh Powered Build In The Making...
n8ball2013 Posted February 18, 2015 Report Posted February 18, 2015 Where are you located in pa? You can strap them but you have to strap them higher than what you think your final impedence is. .5 strapped is .25 at each amp. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted February 18, 2015 Report Posted February 18, 2015 you gonna have a hard time running strapped at .5 SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted February 18, 2015 Report Posted February 18, 2015 Where are you located in pa? You can strap them but you have to strap them higher than what you think your final impedence is. .5 strapped is .25 at each amp. wurd... youll be at 1ohm, or .25........ edit - you can strap at 2ohm, or .5 on the load... divide by 2 on those.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
KO4Life Posted February 18, 2015 Author Report Posted February 18, 2015 I'm 1.5/2 hours east of pittsburgh, jtown to be exact. I just wanna get the lowest impedance possible. I have only ran a sub amp and mids and high amp together before never strapped or anything. Budget Banging On A Budget..... 99 Civic EX Coupe XS Power/SkyHigh Powered Build In The Making...
SIDE SHOW Posted February 18, 2015 Report Posted February 18, 2015 do a search on this forum for TA1.3000D... think pioneerforlife had 2 strapped.....
KO4Life Posted February 18, 2015 Author Report Posted February 18, 2015 OK will do thanks a lot. Budget Banging On A Budget..... 99 Civic EX Coupe XS Power/SkyHigh Powered Build In The Making...
