6V 250Amp Hour Cells to use or not to use for Car Audio?
Would most likely get better/nite answered in the electrical section.
Interested in the answers though.
The way I see it
3 sets of 2 would give a 12v storage with a good ah.
What would the discharge and recharge rate look like though?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yeah it would be 2 in series to make it a 12v battery (max charging voltage reading voltage would be unknown???).
Then 3 sets of those wired in parallel. Gives a total of 3 12v batteries.
Imo with the limited info on doing this for car audio and the work it would take plus the space it would use up isn't worth it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Dude around here use to run a 18 volt setup with a trunk full of 9v volt Batts back in the day.
Should specify they were big 9 volt batts not the little guys.
Hi Guys
These 6V cells are not that big as compared to my 12v that i have but they are almost equal in weight....
12v were 63kg each and these 6v are 30kg = 60kg to make a 12v bank..... so its a loss of 3 kg per set :) also the 6v are newer :)
also remember the 6V are 250 amp hour batteries at 6V - the CCA on them are 5000 each at 6V so when i series two - wont i get a longer time burst of 250 amp? the bank becomes bigger :)
so in total im looking at 750 amp hours with 15000 CCA :)
The way I understand it
Amp hours divide by 2 when 2 are ran in series
So 125 per 2 (12v bank)
So 3 12v banks gives you 375 amps.
Say those 6v batts rest at 6.2 volts, gives you 12.4 resting voltage power back. Typical agm battery is 12.6-12.8. Losing some voltage.
Them you have to consider internal resistance of each battery and all 3 banks as a hole.
How high can you charge them? 13? 13.8? 14.7? 15.6?
How fast do they discharge and recharge? How long can they do this before going out?
Lots of other stats to look into.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1006 Guests (See full list)
