Battery Research Help
Probably not what you guys are going to be expected but I have to write a 15 to 20 page report on a batteries.
I am planning on posting it up here when I am done.
So what would you guys like to see in it?
What i have so far is the difference between lead-acid, AGM and Lithium ion (being composition, uses, pros and cons)
Hit me with anything you guys can think of
compare them to capacitors. how they differ.
compare to caps and amongst them selves
specific energy
energy density
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I guess I could make a spin that each cell works the same as a cell of capacitors. IDK I'll ask today and see what he thinks
even if you cant compare to caps.
compare specific energy
energy density amongst the different battery types.
BMW M340 xDrive
Charge profiles, relative safety, cycle life, weight per kw/h, cost per kw/h, energy density, temperature, moisture, shock or other usage considerations, disposal requirements, common applications, types of construction: separators used, chemical reactions (there is one we commonly accept as a battery but chemically you could say it isn't ;) )
dis guy must know his sheet or he was less lazy than i and actually googled a list of battery considerations
BMW M340 xDrive
Nope just off the top of mah head ;)
I'm actively thinking about most of those since I need a battery bank
make a lithium. :) if you need to source good cells shoot me a pm. but to be honest caps are still the way to go IMO for most applications. unless you start making lithiums to hold in the high 13s or 14s under load
BMW M340 xDrive
amp hour rating, CCA
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
