SIDE SHOW Posted February 25, 2015 Report Posted February 25, 2015 and when you remove the rca's from the m4 the noise stops? may be a ground loop issue through the rca's
viper1315 Posted February 25, 2015 Author Report Posted February 25, 2015 and when you remove the rca's from the m4 the noise stops? may be a ground loop issue through the rca's the m4 isnt even in any more. and i unplug the rcas from all of them and it still makes the noise and every speaker and even ran different runs of power and ground. i havent tried the signal wire though. but i dont think that would matter 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
SIDE SHOW Posted February 25, 2015 Report Posted February 25, 2015 well if nothing is connected to the amp and it's still making noise it's either got to be the 4 channel amp or have nothing todo with the amp at all.... just try remove the remote wire so the amp doesn't turn on at all and see if the noise goes away. prob would help if you said how it's all wired, what headunit you have, how many rca's are going from the headunit to the amp, what 4 channel amp it is ect. hope it's something simple lol
viper1315 Posted February 25, 2015 Author Report Posted February 25, 2015 well if nothing is connected to the amp and it's still making noise it's either got to be the 4 channel amp or have nothing todo with the amp at all.... just try remove the remote wire so the amp doesn't turn on at all and see if the noise goes away. prob would help if you said how it's all wired, what headunit you have, how many rca's are going from the headunit to the amp, what 4 channel amp it is ect. hope it's something simple lol Its some old EFX 600.4 i have had forever, wired from the batteries in the back. it is zero gauge going in i did not have any 4 gauge. and only have one run of rcas and pioneer avh 7500 or something. everything is ran clean. power one side and rcas and speaker wire other side. 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
SIDE SHOW Posted February 25, 2015 Report Posted February 25, 2015 ^^ that all sounds fine, not too how the m4 was getting signal? but it sounds like tis an issue within the 4chan amp
viper1315 Posted February 25, 2015 Author Report Posted February 25, 2015 ^^ that all sounds fine, not too how the m4 was getting signal? but it sounds like tis an issue within the 4chan amp i was jumping from 4 to m4 with signal wire. i am going to try a different amp i think to see what i can get. thanks though i will let you know what i find 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
reedal Posted February 25, 2015 Report Posted February 25, 2015 How did you set your gains? I know some amps (my SQ 3500, and old rockford two channels for me) make a loud hum when you hit the point of distortion according to the DD-1. So maybe your amp is one of those that gives off that kind of hum when the gain is too high? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
ds1919 Posted February 26, 2015 Report Posted February 26, 2015 And you did the Big 3 wiring? Might make a diff, who knows....
