Dual 1 Subwoofer Help Please
CrunkJuice
Ok so my buddy bought a fi team 15 and he is only using 1 subwoofer and he was supposed to get dual 2 to run at 1 ohm and now he cant and is stuck at 4 ohms. We were thinking of getting a stable .5 amp to run on it but we have no idea what do get or even if that is the best option. He has a hifonics 2.1k amp witch is what he was going to use but wants to upgrade if possible.What should we do can anybody help us out?
Ok slow down a bit, and words things in a way that makes it easier on others to help you
What coil configuration are you working with? You say he was supposed to get dual 2's to wire down to 1 ohm so how is he stuck at 4 ohms?
If you have dual 2's you aren't stuck at 4 ohms, 1 ohm is achievable.
If you have dual 1's then you can wire at .5 or 2 ohms.
He bought a dual 1 sub and wanted to run at 1 ohm to use full power out of his amp and the guy that installs his setup says the sub isn't true dual 1 cause one reads .5 and the other .7 so you cant run it at 2 ohms. Im just going off what hes telling me.
Impedance is nominal, it changes at the slightest air movement. It's a dual 1 sub and can be ran at 2 ohms. An "installer" should know that.
My question is how are you stuck asking these questions if you aren't the owner of the sub or the installer? Im guessing you are 1 or the other.
A hifonics 2k is just going to tickle that sub.
Get another 2k and run one per coil, done.
on the FI subs D2 to 1 ohm reads .7 on the meter..Can those amps run at .7 with out protecting ?..but yeah 1 per coil would be ideal
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
What makes you think the amp will ever see that load?
Just because wiring configuration will read that, it doesn't mean the amp will see that load.
*Broke beat me to it.
Singer Alternators
Team Asshole
#anothershittysingerbuild
  • Who's Online   0 Members, 0 Anonymous, 3270 Guests (See full list)
