Financial Mistake--Team Droppin' Hz--'10 Taurus Trunk Wall--Oval box COMPLETED--Video added (5/30/16)--DC Audio, PRV, Crescendo
So I finally got tired of the all black interior so I decided to try and wrap them. Gotta say I'm pretty pleased with how it turned out. Still have more stuff to wrap but I will have to order some more vinyl to finish everything up.
Here's the finished product...
Can't wait to get everything else wrapped.
Got some more wrapping done today. Still have a few more things to wrap. I'll have to order more vinyl still.
Front Upper door trim
Rear upper door trim
Front door handles
As it sits...
You can see that that second half of the door insert needs to be wrapped still. I have those on all four doors and the rear door handles to wrap still.
Will be putting in a large order with my friends at Droppin' Hz soon.
Order will consist of:
50ft of Blue 1/0 SHCA wire
25ft of Black 1/0 SHCA wire
Toolmaker 1/0 to 4g inputs
Toolmaker Dual 1/0 inputs
Toolmaker 7 spot battery terminal
10 pack 1/0 lugs and shrink wrap
Hopefully this is all I will need to get my next build going.
  • 1 month later...
So about a month ago I made an order through CarID and I was told that there was a 4-6 week backorder on the wheels I had ordered. My scheduled ship day was today. I was hoping to receive a good email today, but that's not what I got. Email I received said they had been pushed back another 3 MONTHS. Needless to say, I started looking for a new set of wheels. After looking for a short amount of time I found another set that are almost identical to the original set and $80 per wheel cheaper. Made the call, got my order changed, and they have them in stock. Said they will reprocess my order in the morning, and I should receive them in 7-10 days.
These are the original wheels I ordered...
And the new ones I ordered...
433u-hawk-satin-black-with-diamond-cut-f
Excited to finally get the ball moving.
So Friday I got to go up and pick up some goodies consisting of...
50' of Black and Blue OFC SH 1/0
1/0 to 4g reducers
Toolmaker 1/0 6 spot input battery terminals
Droppin Hz 3D printed box terminal
Lugs and shrink wrap
Also I picked up these to help out with my build...
And since I got these picked up, I got started on my box as well. What we ended up doing was cutting the tube in half and using the halves for the side of the box instead of kerfing wood.
Before we mounted the halves though we channeled the bottom edges of the top and bottom panels so the halves sit flush.
Next we cut 4 posts so we could get the right height on the entire box on all four corners.
And then PL glued in the channels and then screwed the halves to the channels.
And then cut, mounted, and flush trimmed the first baffle for the time being...
4/30
Went back today and started glassing the box. Made a good dent in it, but there is still a ton of work to do.
  • Who's Online   1 Member, 0 Anonymous, 1580 Guests (See full list)
