do you mean the wire fuse or the fuse in the amp?  if youre talking about the fuse for the wire then you will probably be running 1/0 gauge right? the max fuse size you can use for 1/0 gauge wire is a 300 amp fuse... i use 250 amp fuses with all of my 1/0 gauge runs..
18's in a wall to come....Its not all about the posts....check the member #...
what he mean fuse on the wire. he talking bout a fuse you get at the store im lost sorry cause i have the same amp :-[ :-[
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i called maxxsonics and as far as the XI2006D. it doesn't have a fuse in it but the tech told me to just use a 200 amp fuse for under the hood with that amp or bigger if you have additional amps. let me know how good that amp is. i thought about getting one but don't know.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
doesnt the 1206 only have a 80 amp fuse on it
i don't know what size fuse the 1206 has but i know e BXI2006d doesn't have a fuse which actually suchs, you'd definitely need a fuse underhood and then a fused distribution block.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
