MECHMAN Posted June 24, 2015 Report Posted June 24, 2015 i like how they're inverted from the original alternator. looks cool and gives you super easy access to those power terminals! this may be a dumb question, but i just realized that the alternators will also be spun in the opposite direction of the primary, so an alternator pulley can be spun either direction and still work normally? i dont know much about alternators, ive just never thought about the pulley being able to be spun the other direction. Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. 1-888-MECHMAN www.Mechman.com [email protected]
tboorn Posted June 24, 2015 Report Posted June 24, 2015 i like how they're inverted from the original alternator. looks cool and gives you super easy access to those power terminals! this may be a dumb question, but i just realized that the alternators will also be spun in the opposite direction of the primary, so an alternator pulley can be spun either direction and still work normally? i dont know much about alternators, ive just never thought about the pulley being able to be spun the other direction. Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. very interesting, and awesome! im excited to see them all up and spinning!! Fidelity Built to Last Team Sound Asleep 24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/ 2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3 2 DD M3b Maxwell 2.7V 3000F Supercapacitors Pioneer DEH-80prs Focal P165 V30 components Rockford Fosgate T-400.4
graham0599 Posted June 24, 2015 Report Posted June 24, 2015 i like how they're inverted from the original alternator. looks cool and gives you super easy access to those power terminals! this may be a dumb question, but i just realized that the alternators will also be spun in the opposite direction of the primary, so an alternator pulley can be spun either direction and still work normally? i dont know much about alternators, ive just never thought about the pulley being able to be spun the other direction. Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. Well you learn something everyday. That's pretty awesome and really smart on choosing the 250's My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
MECHMAN Posted June 24, 2015 Report Posted June 24, 2015 got the idlers set up. Looks like the outer belt for the alternators will be able to be changed without unbolting everything, thanks to that little ribbed idler on the left. That is a HUGE convenience. 1-888-MECHMAN www.Mechman.com [email protected]
RossGo Posted June 25, 2015 Report Posted June 25, 2015 Very cool! Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
firebirdude Posted June 25, 2015 Report Posted June 25, 2015 Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. Not that the average consumer could do this.... but couldn't you guys just crack the case open and flip the fins around? I mean, they're your alts. You can do any damn thing you want with them. lol
Jhunt94 Posted June 25, 2015 Report Posted June 25, 2015 Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. Not that the average consumer could do this.... but couldn't you guys just crack the case open and flip the fins around? I mean, they're your alts. You can do any damn thing you want with them. lol I was thinking the same thing, except I was wondering about just making new fans 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
CortezDTV Posted June 25, 2015 Report Posted June 25, 2015 No the fins go on one way You just run them in reverse and can't run them to their max potential because the cooling isn't there SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
MECHMAN Posted June 25, 2015 Report Posted June 25, 2015 Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. Not that the average consumer could do this.... but couldn't you guys just crack the case open and flip the fins around? I mean, they're your alts. You can do any damn thing you want with them. lol The fan blades are already made for CW rotation. We could tool up and have our own CCW fans made, but then you would have to order rotors with no fans on them , weld them on here, re-ballance them, etc... The demand just isn't there for it. We are confident this setup will work for how we intend to use it. 1-888-MECHMAN www.Mechman.com [email protected]
firebirdude Posted June 26, 2015 Report Posted June 26, 2015 Most alternators will function running in either direction. The only drawback to running them CCW, (counter clock-wise) is that 99.99% of all alternators out there have internal cooling fans that are designed to run CW. (clock-wise) When you run the cooling fans backwards, you loose about 30% of the cooling for the alternator. That is another reason we opted to use 250 amp Elite series units. The E series 250's have the exact same beefy twin rectifier setup that we use in the 370 amp E series units, so they have less heat potential, and are overly built to withstand more abuse. Not that the average consumer could do this.... but couldn't you guys just crack the case open and flip the fins around? I mean, they're your alts. You can do any damn thing you want with them. lol The fan blades are already made for CW rotation. We could tool up and have our own CCW fans made, but then you would have to order rotors with no fans on them , weld them on here, re-ballance them, etc... The demand just isn't there for it. We are confident this setup will work for how we intend to use it. So you guys just order all your alternator parts from someone else..... then just assemble them?
