can't find the answer!
Think of it like this... Your whole car is your negative cable. Adding negative runs won't hurt but more often than not the vehicle's body is adequate to carry the current demand of your equipment. Generally your money will be better invested in an extra positive run over a negative run
ok so no negative runs. only chassis/frame grounds. ok but you saying an extra positive wont help either?
why would it?
you have 90 amps to give...
you must be implying my alternator? mine is a 105amp stock not that thats a big jump from the 90 you mentioned. i have 2 145amp ad244 for this car just need to build a bracket for second alt mount and swap out the stock.
2000 Cavalier 4 door
XS D925
XS D2400
XS D3100
4 runs of 1/0
Mechman 270
2 DD 9515js
why would it?
Do a POS run....
if anything......
Here's what you do
1. Cut your car in half down the middle
2. Put the two sides back together with rubber insulators
3. Driver's side becomes negative, passenger side becomes positive
4. Never worry about running wires again
5. 1000000db
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
