JBGoodnuf Posted March 11, 2015 Report Posted March 11, 2015 I plan on having a Sundown SAZ-1200D (1x 1200+W) and a Pioneer GM-3400T (2x 60W) I have a single run of 1/0 to the trunk and plan on distributing that into 2 4ga runs to the amps, will the single 1/0 run be enough to handle the power to the amps? p.s i have a stock alternator (90A) and an AGM battery
Broke_Audio_Addict Posted March 11, 2015 Report Posted March 11, 2015 What brand and type of 1/0? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
rockFord_Expedition Posted March 11, 2015 Report Posted March 11, 2015 Your demand is more than your supply. 1/0 will carry 90+A just fine. You system will want more alternator btw. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
reedal Posted March 11, 2015 Report Posted March 11, 2015 If the current rating of the 1/0 meets or exceeds the current draw required by the amps then yes. Same with the 4ga SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
rockFord_Expedition Posted March 11, 2015 Report Posted March 11, 2015 Also OP the length of the run matters, as well as the metallic composition of the wire, but I didn't go that much into it because you only have a 90A alt. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
JBGoodnuf Posted March 11, 2015 Author Report Posted March 11, 2015 What brand and type of 1/0? Also OP the length of the run matters, as well as the metallic composition of the wire, but I didn't go that much into it because you only have a 90A alt. its stinger wire 50%cu & 50%cca the run is shorter than 13' btw im planning on upgrading to a 120A alt will that be enough?
rockFord_Expedition Posted March 11, 2015 Report Posted March 11, 2015 1/0 is plenty for 120A as well Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Broke_Audio_Addict Posted March 11, 2015 Report Posted March 11, 2015 Yep you'll be fine with that. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
