Need advice on laptop purchase
I'm looking for a laptop to run my termlab and download music. The music will be downloaded straight to an external HD via USB 3.0. What specs should I look for to get the best bang for the buck? Larger files I will connect via ethernet cable but smaller files I will most likely just use wifi
I dont see any requirements on the termpro website. Nothing you are planning on doing seems like you would need a crazy expensive laptop. Fastest cpu and most ram you can afford and a fast hard drive 7200 rpm or SSD if funds permit. I recommend Dell for the fact that if anything breaks replacement parts can be obtained off ebay fairly cheaply.
Under Construction
Your internet connection will have the biggest impact on how fast you download. Most new computers will have wireless transfer speeds faster than most ISP's are able to get it to you. Your router will play a big part into the download also. What speed is your internet up/down?
Under Construction
I bought a cheap ass eMachine to run mine so if anything was to happen to it I'm out $300 max
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
Look at IBM Lenovo good price on 1 TB 8gb for 350 at Best Buy. Dell have the #1 break down %.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I have no idea what my up/down speeds are. Never really had a reason to check them out. I'll also buy a new router if it comes down to it
I want a 1TB external HD so I can put it in my center console of my truck for music. That's kind of the whole point of buying the laptop
Your internet speeds will have more to do with how fast you download anything.
Test your ISP speed here. http://www.speedtest.net/
The only other thing you mentioned that I would look for would be USB 3.0 ports.
Something like this may work for you.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834231337
or this
http://www.newegg.com/Product/Product.aspx?Item=N82E16834299058 /lower cost 5400rpm hard drive.
Do you have a amount you don't want to go over?
Under Construction
I'm in the same boat here, Mac guy needs a cheap windows computer. I will never buy a dell or hp again( said I'd never buy windows again) lol.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
