how are you wired at one ohm if you have dual 2.4 coils ?
Do they make dual 2.4's ?
im a lil lost?
"Checked coils on sub (read 2.4ohm each)"
It reads more like 1.3 ohm at the terminals. i said 1 ohm earlier i meant 1.3...
They are dual 2 ohm subs with a DCR of 2.4 I should have been more specific
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
im a lil lost?
weird...
to me, a dual 2 would read 1.4 dcr per coil...........
dual one would read .7 per coil....
DCR should read LOWER .. not higher
wire lower
done
wire to .35 or what ever...
Lol man I only have one sub I cant wire to .35. I get the point about how they should read lower which I figured is usually the case... but they still read 2.3-2.4.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
im a lil lost?
weird...
That is only with Fi, Crossfire, AA etc. type subs mainly. DC, Sundown, blah blah blah, and so on all read right at or .1-.2 over.
OP, the .4 extra could be from internal resistance within the DMM if it is a cheapo. I know most DMM's usually have ~.1 or so internal resistance.
wire lower
done
im a lil lost?
weird...
I understand Thomas.
But, how is he seeing a 2.4 coil on this sundown sub? probably shitty dmm leads.. BUT
So if it is a dual 2, and hes wired at 1 ohm... why would his voltage drop ?
Ill bet with his mayhem, he was making more power... ill bet it was a was a dual one,... at .7 dcr, and he was acutally at .35dcr
know what i mean?
wire lower
done
im a lil lost?
weird...
know what i mean?
I understand completely.... and who is thomas... lol.
OP, I would check RCA connection to make sure they are tight. Im my truck, along with other teammates have seen similar stuff with no power output and ended up being a loose RCA.
wire lower
done
im a lil lost?
weird...
know what i mean?
my bad... wrong name.... lol
also,... the voltage at 32v seems odd to.... i agree
wire lower
done
im a lil lost?
weird...
know what i mean?
The mayhem was a D2, ZV4 was a D1, the tantric I have now is a D2. Zv4 dropped to 11. Mayhem dropped to 12s... you cant tell me there not a problem if im only dropping to high 13s with the tantric even if the resistance is a half ohm higher.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
