So I bought a Tantric HD 12 d2 a week ago and received it yesterday. Today I went to put it in my 2.5 cu enclosure and I am having a problem with the sound/voltage. It doesnt drop ( to maybe low 14s) and something is definitely wrong. I had a problem similar to this last week when I realized my coils on the mayhem need a recone. Voltage drop with zv4/mayhem was to around 12 volts. The way it is playing seems as if it wired very high.
What I did:
-Checked coils on sub (read 2.4ohm each)
-impedance at the output terminals is 1 ohm (car off)
-o-scoped the rca's and output voltage (clean)
- free aired the sub and notice no coil rub at all (seems as if not getting full power) and it sounds perfect
- sub appears to be in mint condition
- changed port tunings (didnt help)
Only thing I can think of left:
- check power/ground input (dont think this is going to do anything)
Tried troubleshooting with a friend and couldnt get anywhere...
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
I'm confused. You getting less output? Anything wrong other than what you're seeing on a voltage meter?
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Where are you reading voltage from? What's your AC voltage on the output of your amp if you play a 40hz tone full volume?
Its hard to describe it just sounds off, my voltage is dropping to 13.8 max if i play 30 hz tone. I had a zv4 prior to this where I was dropping to mid 11s full tult on a 30hz tone at .5 ohm.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
I didnt get numbers for the AC output but I can tomorrow. I didnt see anything out of the ordinary when I checked earlier however.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
So you saw way more drop wired to .5 instead of 1 like you are now.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
"way" more would be an exaggeration...
when I had my mayhem wired to 1 before my zv4 wired to a .5, I was still dropping into 12s
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
Need solid numbers to work with. Voltage at the amp being DMM on the set screws at the amp for your power wire
For the AC voltage output I get 32 volts at full tilt on a 30 hz test tone.... which seems low.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
XS Power XP2000
Sky High wire
Stock alt
