You have an oscope right? Crank that sucker. There's a link in my sig to some test tones you can use too. Try the -7.5 or -5db 40hz track. -5db will be safer, but you aren't running that much power to the mayhem so if you are adventurous, try the -7.5 track ;)
It's the Tantric HD but I'll try the tones.
My bad! Even still, my statement regarding power and tones still applies :)
Cranked up the gain to about 5/8 and seems much better, getting a voltage drop with test tones down to 12.5 or so...
I am kinda concerned of clipping as I dont have an oscope on me atm so Im going to try an not wail on it until I meet up with my friend again.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
Well... play some music.... does the sub get hot? does the amp get hot? If not, don't worry about it.
Did you just turn it up, or use the oscope?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Just because the sub/amp may not be getting hot does not necessarily mean he's running a clean signal.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
