Saz1200 is rated at 14.4 i would go with the SCV with your voltage. And sell the saz. That's just me
most people have said I won't be able to tell the difference, its looking like a gamble on doing that.. But I also see your point also...just taking my time trying to get the pros and con's before I commit.. Edited by tbeats
Get the 2k if you're going to get anything.
2k + or bust.. the saz1200 at 12 volts compares to the svc1500.. the saz1200 is a power house. it does 1200 without even busting a sweat.. i said it before.. its the same amp with a different model name and rating. also some internal stuff to make it more efficient at 12 v but still the same power
Saz 1200 doesn't even do 1200 unless at 14.4v. And op cannot support 14.4v. So he will not be getting 1200 watts out of it. The scv 1500 will do rated or more at 12.4v
this is the 1200 that was tested. wired at .5 nominal
little tanks if you ask me
test was done by Jacob
Test Frequency - 50 Hz
Test Load - 4x SA-12s all in parallel for 0.4375 DCR (1/2 nominal)
Test Electrical - 6x Stinger SPV-70 + 225-Amp Alternator (vehicle only at idle)
POWER : 1770 Watts
AMP VOLTAGE (measured) : DID NOT MEASURE
AMP CURRENT (calculated) : DID NOT MEASURE
ACTUAL IMPEDANCE (calculated) : DID NOT MEASURE
SUPPLY VOLTAGE : 12.65 V
  • Who's Online   1 Member, 0 Anonymous, 1487 Guests (See full list)
