Can someone explain this?
plugdumps
Hey guys, new to the forum and couldn't find anything related to this is my little bit of research, but I am desiging a box for 2 sundown audio sa 10's for my 2004 regular cab silverado. While playing around in Torres I noticed this and am now wondering. Does .1inch really make my box that much bigger? Thanks in advance guys!
This is what I originally had (just random numbers entered for now)
And here is with an extra .1 of an inch
I don't understand it, but I was able to reproduce the exact same thing. That 0.1 should only add like 40 cu in.
It looks like Torres doesn't like decimals, if you enter 8 you get much more reasonable results. Using 8 I got 2.57 cu ft, which sounds about right.
*I'm a software test engineer, so I couldn't resist messing with this. It doesn't seem to mind negative numbers, lol. Shitty programming if you ask me, it shouldn't allow negative values, and it shouldn't have a problem with decimals.
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
You can double check it.
in inches, HxWxD / 1728 tells you how many ft^3 you have.
When you have different depth dimensions like your second example, just average the two and plug it in
Unless you are building a wedge style enclosure you only need to use depth 1.
  • Who's Online   0 Members, 0 Anonymous, 939 Guests (See full list)
