GymJunkie Posted March 21, 2015 Report Posted March 21, 2015 My current fuse holder is AGU, holding a 60a fuse. Since my current fuse looks like it has some kind of corrosion on the inside I'm just going to be buying a whole new holder and everything. One of my questions is, will it make any kind of difference to use another type of fuse? Also, is there any harm in using a fuse rated at a much higher amp than is actually needed? For example my current system has 2 30a fuses on the amp (1000w) and the current fuse has had no issues blasting full volume, could I use a 150a or even higher if I wanted or should I be damn sure to stay exactly at or slightly above 60a? 1993 Cadillac Fleetwood Brougham. Jensen UV10 DVD HU Two 12" Sony Xplode (temporary)
mothra Posted March 21, 2015 Report Posted March 21, 2015 you fuse according to the wire's current capability. at the end of the day you can put whatever fuse you want but that's the standard answer. if nothing changes, nothing changes You don't know what you don't know, till you don't know
GymJunkie Posted March 21, 2015 Author Report Posted March 21, 2015 I have no idea what the cable is rated at, I bought it a loooong time ago. Scosche 8ga though if that helps at all :-/ 1993 Cadillac Fleetwood Brougham. Jensen UV10 DVD HU Two 12" Sony Xplode (temporary)
GymJunkie Posted March 21, 2015 Author Report Posted March 21, 2015 Would I be safe using an 80amp AGU fuse on my 60amp system? KnuKonceptz only has 50 and 80a. 1993 Cadillac Fleetwood Brougham. Jensen UV10 DVD HU Two 12" Sony Xplode (temporary)
Popwarhomie Posted March 21, 2015 Report Posted March 21, 2015 KNU OFC 8 gauge is rated 60 amps for 20' runs. I would not put an 80 amp fuse on your wire. I would do 50. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
GymJunkie Posted March 21, 2015 Author Report Posted March 21, 2015 I thought the power fuse should match the total amount of of the amp fuses. So wouldn't using a 50a, ten under, be asking for a possible problem? And I'm not using knu cables its the crappy scosche cabke 1993 Cadillac Fleetwood Brougham. Jensen UV10 DVD HU Two 12" Sony Xplode (temporary)
Popwarhomie Posted March 21, 2015 Report Posted March 21, 2015 Your amp fuses will protect your amp. Your wire fuse will protect your wire. Don't want your wire melting. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
GymJunkie Posted March 21, 2015 Author Report Posted March 21, 2015 Oh OK. 50a it is, thanks for the info 1993 Cadillac Fleetwood Brougham. Jensen UV10 DVD HU Two 12" Sony Xplode (temporary)
islandpride684 Posted March 21, 2015 Report Posted March 21, 2015 http://www.bcae1.com Tab 14 on the right side Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Broke_Audio_Addict Posted March 21, 2015 Report Posted March 21, 2015 you fuse according to the wire's current capability. at the end of the day you can put whatever fuse you want but that's the standard answer.You should fuse for your current demands as long as they don't exceed the current carrying capabilities of the wire not just fuse for the wire's capabilities.If I was running 1/0 and had a 100 amp draw what's the purpose in me fusing for 300 amps? At that point your fuse is doing nothing. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
