1st design need help!
Jwill96
well that box will be very musical, there is 4.068 cubes before woofer displacement and i have 17in^2 of port per cube of air space, tuned at 37hz but will play anything for 20-60 easy, if you use mdf bracing it wouldnt hurt to go 23" tall so your still at 4ft^3 after all the displacment. and you can double baffle at will.
Thank you I greatly appreciate your help. If I was to use 1" dowel rod, I have an adundace of because my dad makes walking sticks, should I still add the extra inch and would that affect the port length at all?
Thanks Joe x for your input. I don't believe I would have the min port clearence due to the fact that the 30 inches is from one the left wall (if facing the rear of truck) to the single 40% seat I'm keeping in there.
  • Who's Online   1 Member, 0 Anonymous, 1737 Guests (See full list)
