Aftermarket subs with a Bose system...sound?
Was wondering if anyone here has added subs and kept their 9 speaker bose set up? I don't want to have to upgrade all my speakers and remove the factory amp at this time. I've already ordered most of my gear for the new set up, just wondering if the music will be heard over 2k watts and 2 15's
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
Well, you will be able to hear a lot more than somebody with the same sub set up and a stock 4 speaker set up lol. Just depends on ur taste/needs out of a system.
Edit: are you going to remove the stock sub?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Don't take for granted that you will be sending a clean signal to your amp. How do you plan to do this? Most Hi-Low converters that I have seen tested are garbage.
Levels can be adjusted so that your music is balanced, but you will most likely not be satisfied with the low end if you do.
I'm not using h/l convertors , I'm installing a Pioneer AVH-X4700BS with all the adapters to keep factory Bose (including woofer) system rear entertainment , and steering wheel controls. Running out the pre amps just like with any other h/u to sub amp
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
Or did you mean the h/l convertor for the h/u to bose amp? I was thinking you meant speaker l/o convertor
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
  • Who's Online   0 Members, 0 Anonymous, 3402 Guests (See full list)
