8 DC XL Elite 15's,4 DC 5k's, 3 370 Singers, 2 80ah JY's, 28's
that's a mad amount of rise...
was blown away when I read about it on Facebook. Guess it's just the enclosure? I mean it's mad efficient, tipping close to a 60. Well not really close, but a lot closer than a 55.
Not mad efficient. Sealed side is tiny.
a 158.1 on 1 10k, clamping 2500w at 6.6 ohms....
yeah I would most definitely consider it an efficient enclosure in terms of using power to put up good numbers.
For what it SHOULD be, not efficient. That rise should be about half that, and should be clamping about 12kw and doing a 160+.
Since the enclosure looks so good i'm not going to mess with it at the moment. I'm going to re cone the subs and add power. One of these days I will give it back to Daniel and let him create another masterpiece.
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
That rise is a bitch though
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
That sealed side needs to be bigger. Plus, I dont every think both amps regardless of rise were ever working together or correctly.
Something is fishy, When I wired the amps independently, they played. Checked all the subs, they were fine. I will dig into everything and get it figured out. Gives me something to do when I get bored
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
foxracin4 had issues when he strapped his amps as well. Pretty sure one would protect or something funky like that aswell.
hopefully he will chime in, he seems to pop in when he is mentioned.
Amps never protected, What happened was, we were only getting about 101,103 Ac volts from both amps strapped. When we unstrapped them ( gain matched) there was no more nor less output.
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
there shouldn't be a change an AC voltage there should only be a change in amperage, thats why you can set your amp with a dmm if you know the ohm load and theoretical wattage output, the only change should be amperage between ohm loads not different voltages.
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
Oh, thought it doubled. Could be board difference, but i get nearly 180vAC unloaded on my 2 D9's strapped, his 10k's strapped was 103vAC clean.
But still, voltage drop and "loudness" didnt change in the slightest from 2 strapped at 1 to 1 amp at 1.
At the end of the day, I firmly believe both amps were NOT working together and the whole time only 2 subs and 1 amp were actually functioning.
So, i'm not sure what this actually affected but, My radio (80prs) has a setting for stereo and mono on the sub out. It was on stereo and I switched it to mono, now it seems louder to the ear-o-meter. I have more voltage drop which tells me the amps have more output. Can somebody tell me what happens when the output id on stereo and when its on mono?
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
