Which groupe 31 should I get?
I am in the process of installing my system which as follow. I have a BC3500 which is running two SA zv2 18's wired in parallel down to 0.5 ohm. Up front I have a Singer 270 amp 6 phase alternator and that is powering an Optima Red top. I have two runs of 2/0 welding cable running from the front to the back. I was told I should get two group 31 batteries in addition to what I already have. I am looking at the Duracell's from Sam's club because they are in my budget.
My question is, can I run the duracell marine battery. It does say its AGM http://www.samsclub.com/sams/duracell-marine-battery-group-size-29hm/prod3590216.ip?navAction=
Or do I need this one which says it is an AGM but more expensive? http://www.samsclub.com/sams/duracell-agm-deep-cycle-marine-and-rv-battery-group-size-31dtmagm/prod3590232.ip?navAction=
Or is there another one I should look at? I don't want to spend anymore than $200 per battery though because I am broke.
I'm pretty sure the duracells are rebranded deka's which will be just fine (not positive on that though)
You can get an actual deka from Remybatt.
Other rebranded deka's: diehard, oreillys super start....I think there's a few more but not sure about availability
Singer Alternators
Team Asshole
#anothershittysingerbuild
Check the resting voltage of your optima. If its 12.6 or lower I'd replace it as well
how long should I let the battery sit before I check it. Its currently on my truck and I use it everyday
Ideally you would remove(or electrically disconnect) it from the vehicle, charge it, then let it sit for a few hours
I have a diehard platinum under the hood and if I hadn't gotten such a good deal on my rear bank, I wouldn't hesitate to run more.
Btw, OP, fix the spelling in the subject heading.....it's bothering me lol
Singer Alternators
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
