First Build - 6th Order Trunk on 2k
I had a plan to do a budget build and then blew my budget.
This is the first build I have ever done, never used fibreglass or done carpeting or anything audio related so some things are a bit rough :P
Even so, pretty happy how it turned out.
Was originally designed as a 4th order tuned at 64hz but designed in a way so I could convert to a series tuned 6th
The 6th order conversion I am running now sacrificed a little bit around the 60hz range for alot of gains down low. It dips down to 19-20hz pretty reasonably now.
It is currently tuned at 27hz and 64hz respectivly.
Outer @ 2.2 cu F
Center @ 2.6 cu F After displacement.
I have a high output alternator sitting on my back seat that should solve my voltage issues (Current alt is on its way out)
I would guestimate im getting about 1200-1300 watts to the woofers due to my cooked alternator.
Bits
4x 12" Pioneer TS-W3003D4
2x GM-D9601
1x GM-D8604
1x Pair Polk MM6501
1x Pair Pioneer TS-A6995R
Optima Yellow top (XS Power was just gonna be too much to ship)
SHCA 1/0 OFC
Total cost was around 4000 of my Australian Paceos.
Parcel Shelf
http://imgur.com/a/bcYNv#0
Door Pods
http://imgur.com/a/efPC0#0
4th Order Box build
http://imgur.com/a/soO5K#0
6th Order Conversion
http://imgur.com/a/4rmPl#0
Electrical
http://imgur.com/a/OiHnM#0
There is room for 2 extra batteries up the back which will eventually happen.
The new alternator will be dropped in soon.
If you leave it till the last minute, it will only take a minute.
Build Log - 4x12's Trunk Firing 6th
Interesting design choices. Can you provide some details how that 4th is now a 6th, I'm a little lost on what you did there.
Also, since it is a 6th order, by the very nature of a 6th, I wouldn't think you'd be able to hear anything around 20 Hz due to steep slope and rapid drop off.
The outer chambers are ported to the interior chamber via that port at top. Its handles down to 22-23hz pretty nice and starts to roll off down to 19hz (Where i would start losing cone control if i tried going lower)
I seem to have some pretty reasonable cabin gain, also it loves having the windows open for the lows.
Edit: Unfortunatly I dont have alot of pics of the 4th to 6th conversion.
Looks pretty cool.
You'd probably get more attention on your setup when the pics are linked properly :)
Got a few extra pics of box from interior of the car.
I would like to seal the back from the front of the car, but im not entirely sure how to go about it.
I would guess ill just silicone up the power runs and then im not too sure... some good ideas would help me a lot.
http://imgur.com/a/PfsAS#0
  • 1 month later...
Been pretty busy so haven't been able to do much at all, but finally got around to slapping a bit of dampening up the back. So many rattles have been squashed finally.
Now I have to prepare to do a bit of work up the front preparing to install a VM-1 OD-1 and LC1 which im pretty keen about.
Still need to finish sealing front to back have some good ideas of how to do it now. Just need the time.
Sorry for the potato quality pictures, it was night.
can you post them like this so I dont have to open 20 windows to see your pics?
I clicked embed on your link then right clicked copy and pasted
if you cant or dont want to do it like this that is fine thanks for sharing anyways and I like that port I wish it was painted!
Yeah sure, was just trying to keep things in mah post clean. Ill start going thru and fixing that up :)
Edit2: Doesn't look like I can use embed function, probably Iframe/JS restrictions.
I too wish the port was painted, it probably will be soon.
Edit:
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
