chado_345 Posted April 10, 2015 Report Posted April 10, 2015 I have a pioneer deh-p4100ub it have a few settings i would like some help setting it to get the best sound out it what hz i should set my lows at my mids at and my hights at and were should my cut off freq for my sub be set at the settings i have right now on the headunit are the lows at 40hz-Q2w the mids at 200hz-Q2w and the highs at 3khz-Q2w my cut off freq for my sub is 63hz and my hpf is at 100hz and i have my src level at 2
Broke_Audio_Addict Posted April 10, 2015 Report Posted April 10, 2015 All that is personal preference and driver dependent. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
SIDE SHOW Posted April 10, 2015 Report Posted April 10, 2015 try set the eq to flat/off and set the hpf to 80 and the lpf to 80
dbmode2 Posted April 10, 2015 Report Posted April 10, 2015 This is my first time being on here and found some very useful links a data for this topic on here and use there data sheet to here is the link on this site for that as far as setting the EQ on a radio/indash EQ go here http://www.stevemeadedesigns.com/board/topic/4319-sq-how-to-tune-your-system-a-must-read/
Fourleaf Posted April 13, 2015 Report Posted April 13, 2015 Don't boost any frequencies unless absolutely necessary. It's best to lower others around it to get the tone you want, then turn up the volume. Also, try to use as little of the boosting settings and things like that head units have as possible. Preferably none. Just the HPF and LPF. I found that my system benefited hugly when I turned everything off but the filters. Once that's dialed in you can tune the 3 band or 9 band or whatever it is you have
Baydestrian Posted April 14, 2015 Report Posted April 14, 2015 Try going to the General Audio section lol 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
