need some help setting some settings on my head unit
I have a pioneer deh-p4100ub it have a few settings i would like some help setting it to get the best sound out it what hz i should set my lows at my mids at and my hights at and were should my cut off freq for my sub be set at the settings i have right now on the headunit are the lows at 40hz-Q2w the mids at 200hz-Q2w and the highs at 3khz-Q2w my cut off freq for my sub is 63hz and my hpf is at 100hz and i have my src level at 2
Don't boost any frequencies unless absolutely necessary. It's best to lower others around it to get the tone you want, then turn up the volume. Also, try to use as little of the boosting settings and things like that head units have as possible. Preferably none. Just the HPF and LPF. I found that my system benefited hugly when I turned everything off but the filters. Once that's dialed in you can tune the 3 band or 9 band or whatever it is you have
Try going to the General Audio section lol
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
  • Who's Online   0 Members, 0 Anonymous, 1586 Guests (See full list)
