Do they make Sound Deaden water proof?
right you are able to install it in places that will get wet and it will be fine. It needs to be dry when installed but once its adhered to the surface then you are good
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
The high quality butyl rubber Second Skin uses is highly water resistant and once applied to a dry surface and bonded well it will keep water from penetrating. The butyl used in automotive windows which is highly waterproof is very similar to the quality butyl used in Second Skin Damplifier/Damplifier Pro. Thanks for the info from the other two members also, keep up the great work.
Ok cool thanks a lot for the info
