d-nice88 Posted April 22, 2015 Author Report Posted April 22, 2015 Im gona use an nvx xpld3k to power and the depth is where im having my issue I can proly do 29.5 but not 31.25 cuz ill be hitting the trunk latch
Joe X Posted April 22, 2015 Report Posted April 22, 2015 Here is a suggestion for the DCL4 15s subs/port forward, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 7 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
d-nice88 Posted April 23, 2015 Author Report Posted April 23, 2015 Done deal thanks joe once again im off to build this thang
d-nice88 Posted April 23, 2015 Author Report Posted April 23, 2015 Insted of doing a double baffle I can just use some chop mat and resin to strengthen thr box ?
MrBigs63' Posted April 23, 2015 Report Posted April 23, 2015 With the size of those subs I would double baffle. Chop mat is better than nothing, but I would double baffle.
Joe X Posted April 23, 2015 Report Posted April 23, 2015 Insted of doing a double baffle I can just use some chop mat and resin to strengthen thr box ? Yes you can do that, if you have 30D I can throw in an extra layer to the baffle if you want without any significant loss in the spec.
d-nice88 Posted April 23, 2015 Author Report Posted April 23, 2015 I would lose some internal volume as well too..
d-nice88 Posted April 23, 2015 Author Report Posted April 23, 2015 ok can you do it for me then please joe
Joe X Posted April 23, 2015 Report Posted April 23, 2015 Here is the update subs/port forward, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 7 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
d-nice88 Posted April 24, 2015 Author Report Posted April 24, 2015 Again very appreciated for all that uve done joe.
