Kyblack76 Posted April 21, 2015 Report Share Posted April 21, 2015 Just tested the HU with the DD1 and its distorting at 32. Is that normal? I know a lot of you say it's clean throughout. fucking wait...... (like your alt) tested your head unit at what over lap.... did you do it right? a "station" that was all static ? .. how does the USB play ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
dbmode2 Posted April 21, 2015 Report Share Posted April 21, 2015 It sounds like to me the speaker wire leads are touching the HU or each other Link to comment Share on other sites More sharing options...
BigManAC Posted April 21, 2015 Author Report Share Posted April 21, 2015 Just tested the HU with the DD1 and its distorting at 32. Is that normal? I know a lot of you say it's clean throughout. fucking wait...... (like your alt) tested your head unit at what over lap.... did you do it right? a "station" that was all static ? .. how does the USB play ? Yeah I know right, I have shitty luck. I followed the manual for the DD1. Set all EQ's to 0, plugged an rca into the top of the DD1, played track 1&2 (both distorted at 32). I thought about the station thing and switched it over to BT and had the same issue. Like I said may be me shitty luck. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 21, 2015 Report Share Posted April 21, 2015 It sounds like to me the speaker wire leads are touching the HU or each other he said he turned the internal amp off. probably not something to do with speaker leads. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
BigManAC Posted April 21, 2015 Author Report Share Posted April 21, 2015 no touching here haha 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw Link to comment Share on other sites More sharing options...
dbmode2 Posted April 21, 2015 Report Share Posted April 21, 2015 no touching here haha what is shielding them under that heat shrink? Link to comment Share on other sites More sharing options...
Jessica Posted April 22, 2015 Report Share Posted April 22, 2015 per the static issue: did you unplug the RCA from your amp while the headunit was on while you were testing with the dd-1? per the clipping at 30 issue: Also, where are you checking your headunit from, the amp or right of the RCA cable? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
dbmode2 Posted April 22, 2015 Report Share Posted April 22, 2015 If I did my wire leads like this to my HU my radio and everything else will be static as well the +/- are to close to each other Link to comment Share on other sites More sharing options...
OrionStang Posted April 22, 2015 Report Share Posted April 22, 2015 If I did my wire leads like this to my HU my radio and everything else will be static as well the +/- are to close to each other The heat shrink is the shield. Stop trying. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
dbmode2 Posted April 22, 2015 Report Share Posted April 22, 2015 damn I am done here have fun people there's the problem If I did my wire leads like this to my HU my radio and everything else will be static as well the +/- are to close to each other Link to comment Share on other sites More sharing options...
