Testing amps on alt
It doeant drop under 14 but bass is alote lower
I turned down gain
Turn the gain down for starters.
To where?
Did your voltage pick up?
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
Okay how do I see how good my ground is( im just going to run the ground on amp to the battery ground to make sure it wont be am issue
keep this in mind
an electrical system is only as strong as the grounds... can have beyond strong electrical on paper
shit grounds your voltage will drop like a rock
With a multimeter. Place one probe on the amp ground input, the other where your grounded to your frame, set dmm to read resistance, and you need to be as close as possible to zero. If you're close to an ohm then you need to find a better ground using the same method
Even when reving it there still is a bad voltage drop. Well ill guess ill find out if its the alt tomorroW by using a clamp meter
Okay I just ordered a clamp meter, I still seem to be getting bad voltage drops all the way down to 11.7 and amp gain 60% on deck 0. From alt to amp I get about a .7 drop. The belt is Tight, alt dual set up is a dc270 only running to the amp xdi2000 arc audio,
what clamp ? link me
also.. is this at idle ? Your alt may not make shit at idle....... rev it up.
Im just spit balling...
My batt stays above 13 when car has been off. Mayby ground
could be that you have bad batteries. with the combination of bad batteries and clipping your voltage will suffer
Could be tons of things, you're going to have to trouble shoot them one by one.
bro.. battery resting voltage means squat when they cant handle a load.. seen many batteries rest at 12.8 and drop to 7 volts when cranking the engine. could be many things but the gain set up at 60% is one of the problems
I lowered the gain to around 35 40% and get very little drop BUT bass has droped alote. Well im going after ground next
