Testing amps on alt
DSC_0260_zpsdrszzkvs.jpg DSC_0259_zpsywtynjbu.jpg DSC_0258_zpsfa3as4rk.jpg DSC_0256_zpsadlovb21.jpg DSC_0255_zpsloiyjlw2.jpg DSC_0253_zpsp8d6lyar.jpg DSC_0252_zpsepevl9ww.jpg
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
Okay grouns are zero gauge sky high, Ground from alt case to batt, And the amp is ground to bottom floor. Ill be changing that running 0 gauge from amp straight to batt.
The subs have 12 gauge for now, I already have 8 gauge will be adding it as soon as i build my new box It will be tuned to 32Hz i got it from ram designes
Its 12 is was all the wire i had last week i have now the 8 gauge going on, There in the bottom pik
i dont like how you wired that sub.. how thick is the wire? 10 gauge?
The ground in back is on one of those other terminals you twist to tightin. It will be replace like the one you crimp like on alt
Voltage drop is perfectly normal across a length of wire due to resistance.
You should redo the rear ground and run it straight to the frame.
Im going to run it straight t0 negative on front batt, as soon as i get another batt i will put batt in the back, I have 2 xs3400s but ones is on my stock location running car
  • Who's Online   2 Members, 0 Anonymous, 870 Guests (See full list)
