hoit Posted April 27, 2015 Report Posted April 27, 2015 ...unless you want to go sealed...but most will not suggest due to efficiency, although it will give you a flatter response. are all the subs the same specs? 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
DJ JDub Posted April 27, 2015 Author Report Posted April 27, 2015 4 are exactly the same, the other 4 are different but are exactly the same to each other.... make sense?
hoit Posted April 27, 2015 Report Posted April 27, 2015 I don't know...honestly, I'd pick circle OR square, and sell the others...use the money for electrical upgrade, amps, etc... 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
Jessica Posted April 27, 2015 Report Posted April 27, 2015 yeah, just pick 4 and use those, like i said, you can mix and match, will it sound good? maybe, maybe not. Best just to keep it simple Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Joe X Posted April 27, 2015 Report Posted April 27, 2015 OP would you mind listing your subs? Hope is not a collection of all different subs or something like that.
