Mustang2dakota Posted April 27, 2015 Report Posted April 27, 2015 I've been having a problem the last few days with a set of my subs cutting out randomly and am turning to you guys for help. I'm running 4 subs each on separate amps wired to 1ohm. One pair is perfectly fine, but the other pair randomly cuts in and out and also makes a faint "popping" noise. The gains on both amps are set with an o-scope and a clean -7 40hz test tone with the LPF set at 80hz. I've double checked RCA's,ALL of my wire connections,and checked the ohm's on each voice coil of the two subs that are giving me problems.Not really sure what else to look at so suggestions are appreciated. 2014 JKU Sound: pioneer xav-65 4 12in pioneer tsw3003d4 2 pioneer gm-d9601 (much more in route) General: 18in worx rims 33in tire stinger src bumpers light bars 6k hids 2in leveling kit 3.25in lift The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
Joe X Posted April 27, 2015 Report Posted April 27, 2015 If two amps are failing simultaneously each independently connected to their respective subs with same symptoms it should be any resources these two amps share, signal, turn on, input power.
Jhunt94 Posted April 27, 2015 Report Posted April 27, 2015 If two amps are failing simultaneously each independently connected to their respective subs with same symptoms it should be any resources these two amps share, signal, turn on, input power. He said one pair is fine, and the other pair is the only ones cutting in and out. OP can you swap speakers from one amp to the other. If the problem follows the speakers, then pull them and check them. If the problem only happens on one amp then recheck connections, swap rca's, and anything you can think of. You could have a bad amp. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Mustang2dakota Posted April 27, 2015 Author Report Posted April 27, 2015 If two amps are failing simultaneously each independently connected to their respective subs with same symptoms it should be any resources these two amps share, signal, turn on, input power. He said one pair is fine, and the other pair is the only ones cutting in and out. OP can you swap speakers from one amp to the other. If the problem follows the speakers, then pull them and check them. If the problem only happens on one amp then recheck connections, swap rca's, and anything you can think of. You could have a bad amp. Good point. Ill check tomorrow after i get home from the gym. A bad amp has been lingering in my mind..... JoeX- only 1 set is doing this, but thanks for the suggestion. 2014 JKU Sound: pioneer xav-65 4 12in pioneer tsw3003d4 2 pioneer gm-d9601 (much more in route) General: 18in worx rims 33in tire stinger src bumpers light bars 6k hids 2in leveling kit 3.25in lift The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
MrSkippyJ Posted April 27, 2015 Report Posted April 27, 2015 So what joe said still works, find out what is common between the 2 failing amps that is different than the other two amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Mustang2dakota Posted April 28, 2015 Author Report Posted April 28, 2015 So what joe said still works, find out what is common between the 2 failing amps that is different than the other two amps. That's what I tried at first. But I cannot find any difference. Both Amps are putting out 42.3 volts,and every connection is secure. I'm going to swap the Subs and amp and see if the problem continues on the same side; if it does continue then it's my subs. If it stops and transfers to the opposite side then it's my amp. Im not exactly sure what It would be on the amp causing this proble tho. 2014 JKU Sound: pioneer xav-65 4 12in pioneer tsw3003d4 2 pioneer gm-d9601 (much more in route) General: 18in worx rims 33in tire stinger src bumpers light bars 6k hids 2in leveling kit 3.25in lift The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
ALPINE408 Posted April 28, 2015 Report Posted April 28, 2015 The op mis spoke he only has 2 amps not 4.... Op your original post 4 subs each on separate amps wired to 1ohm. Sounds like 4 amps to me then your reply said a pair of amps how many amps do you have for proper advice Have you ever had your woofers blown?
Guest Posted April 28, 2015 Report Posted April 28, 2015 not real sure how many amps youre running but maybe your headunit is failing at putting out enough remote power to so many things run the remote from the fuse box under the steering wheel
firebirdude Posted April 28, 2015 Report Posted April 28, 2015 not real sure how many amps youre running but maybe your headunit is failing at putting out enough remote power to so many things run the remote from the fuse box under the steering wheel Relay off the head unit's remote turn on. 85 to ground, 86 to remote turn on, 87 output to all amplifiers, 30 to +12V constant, 87a will go unused. This way, the amps will turn on/off with the head vs with the vehicle. Secondly, you're not adding a separately fused current draw in parallel to another fused circuit, all on the same size factory wiring. Example, you have a 5 amp factory fuse, you install the splitter pictured above and throw two 5 amp fuses in there, the factory component draws 4 amp and your add-on draws 4 amp, neither enough to blow their respective fuse, but 8 amp is pulled through the factory wiring on the fuse block (an ignition source in this case, so not all off one heavy gauge wire input). Yeah, not a huge deal in this particular case. But it's bad practice regardless. Same reason we don't use t-taps although they might work fine in one particular case. That said, if the OP truly only has two amplifiers (and not 4 as first said), this is not his problem.
Jhunt94 Posted April 28, 2015 Report Posted April 28, 2015 I don't know where ya'll are getting 4 amps from but he said he has 4 subs, and then says one pair is fine and the other is acting up. So if he's got four subs and saying there wired to one ohm per pair, then it looks to me like he's got 4 D4 subs on two amps. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
