mike-g Posted April 29, 2015 Report Posted April 29, 2015 Curious if I will gain anything by recessing 2 12's with a double baffle 3\4 mdf or is it just visual?
n8ball2013 Posted April 29, 2015 Report Posted April 29, 2015 visual. The bigger the woofer the better chance of crushing a finger too. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Tarball Posted April 29, 2015 Report Posted April 29, 2015 if you do it make sure you add a little bit extra on the outer circumference for clearance . CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
mike-g Posted April 29, 2015 Author Report Posted April 29, 2015 Thanks for the input,I'll probably not flush mount because I cut the holes first,and can't make a jig now,rookie mistake, lol and there will only be about 1\2 " on the outsides of subwoofers,not sure if it matters with double baffle but probaly alot stronger without recessed sub's, unless someone has a good trick,I suck free handing with the router lol
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 Go get a 1/2" board and a face to the box. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
