sundownaudio Posted April 29, 2015 Report Posted April 29, 2015 hey guys i have a stock 90 amp alternator what size fuse whould i use for my big 3 upgrade? (currently have a 250amp fuse installed) also having my amp grounds around 3 feet long would that cause problems ? i sanded the paint off the metal but it has started to rust would that be an issue ? how to solve ?
rockFord_Expedition Posted April 29, 2015 Report Posted April 29, 2015 # things to consider when chosing fuse size: Just don't fuse any higher than what the run of wire is capable of carrying. 250A for a 90A alt is a bit high. Yes ground runs should be short, but so should any run of wire. You want them as short and girthy as possible within reason. It comes down to current carrying capabilities and voltage loss. 3ft. is an acceptable length. If your ground location is rusting, find a new one. Use a dielectric grease to prevent corrosion. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
gdaigle Posted April 29, 2015 Report Posted April 29, 2015 Since its a 90 amp alt, I would use a 90 amp fuse or as close as you can get to 90. 250 is too big for a 90 amp alt. U definitely don't want to ground to a rusty surface. You want a clean bare metal surface to ground to. System: Pioneer DEH-8400BH 4 Alpine Type R 6.5's 4 Soundqubed PA 6.5's 4 Soundqubed Supertweets Hifonics BRX 640.4 Crescendo S800/4 2 Soundqubed Q1-3500.1s strapped @1ohm 2 Soundqubed HDC4 18's 11 Cubes net @37hz (Subs up, port back) 2 DC Power 250 HD's 1 DC Power 300 SPX DC Power triple alt bracket 5 Kinetik HC 1800's 4 runs of 1/0 OFC power cables 4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket iPad Air in dash 300+ sq ft or sound deadening
ToNasty Posted April 29, 2015 Report Posted April 29, 2015 Since its a 90 amp alt, I would use a 90 amp fuse or as close as you can get to 90. 250 is too big for a 90 amp alt. U definitely don't want to ground to a rusty surface. You want a clean bare metal surface to ground to. No, you aren't fusing the alt, you ar e fusing the wire. If you are using 1/0 then I'd do a 250 amp. ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 What he is saying is there is no reason to fuse higher than the current you can actually supply and he is correct. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
hdorre Posted April 29, 2015 Report Posted April 29, 2015 Since its a 90 amp alt, I would use a 90 amp fuse or as close as you can get to 90. 250 is too big for a 90 amp alt. U definitely don't want to ground to a rusty surface. You want a clean bare metal surface to ground to. No, you aren't fusing the alt, you ar e fusing the wire. If you are using 1/0 then I'd do a 250 amp. i thought the same until kyle taught me a lesson... lemme see if i can find his reply. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
hdorre Posted April 29, 2015 Report Posted April 29, 2015 lets say i have a alt,.. that does 100 amp But, i put a 2/0 wire on it.. cuz.. MORE IS BEST, and COOL right? would you fuse it to 450 amp ? ... then your wire IS the fuse............. this happens when running "duals" and many other times....... fusing to "wire load" is NOT always best...... not with what "we" do... On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
