Quantum Audio QB1000d do rated? Anyone with bench numbers?
Do-LowHrzHurts
The gain is not a volume knob, it is meant to match the input voltage from your rcas.
I understand the logic. Its just to see what the amp could do its just burping it to check voltage output at the 75% efficiency range. I need to order a DD-1 to set my gains. should have got one during Christmas when they were all on sale. would even consider a used one really.
Current build
300amp alt
(1) xs power d4800 up front
(1) Optima yellow top 34 out back
All 1/0 skyhigh car audio power and ground including big 3/4
(2) Hyphonics 2000.4
front doors 5.25" memphis mclass comps don't recall exact model#
future plans to run (2) pair 6-8" mids each front door.
rear ski port 6.75" Alpine Type X pro series running passive
rear doors factory 5.25" need better speakers.
(1) ? sub amp maybe sundown saz-4500d
(1) ? Subwoofer maybe team 15"
getting by with a db drive 2400.1 class ab amp thats doing a good 660ish
watts rms to single JL audio 13w6v2 @ 2ohms
box 2.86 cubes slot port 32hrz
def need way more batteries.
https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
You are missing the point here.
If you want to keep that amp don't do it.
Where the gain is set has nothing to do with efficiency either though.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
lets not get to tech here. Are these amps that bad will I pop this pos with the gain at 80%? lol
Current build
300amp alt
your question makes no sense at all. where you set your gain is completely dependent on the voltage level of the input.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 724 Guests (See full list)
