Do-LowHrzHurts Posted May 2, 2015 Report Share Posted May 2, 2015 Curious to know if anyone here on SMD has any experience with a Quantum Audio QB1000d amp. Specs say its good for 1000 watts @2ohms. Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate Link to comment Share on other sites More sharing options...
n8ball2013 Posted May 2, 2015 Report Share Posted May 2, 2015 It's bad. Really bad THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
OrionStang Posted May 2, 2015 Report Share Posted May 2, 2015 And its in general audio section. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted May 2, 2015 Report Share Posted May 2, 2015 My homey got the 3000 watt version and it sucks Link to comment Share on other sites More sharing options...
Do-LowHrzHurts Posted May 2, 2015 Author Report Share Posted May 2, 2015 got it for free so no loss here will give wife some much needed beats with a single 10" or something. or dual 8" subs. Is there an out of the blue section on this blog I can post questions like this? I'm gonna try running it full tilt or maybe 80% and check output on volt meter. Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate Link to comment Share on other sites More sharing options...
n8ball2013 Posted May 2, 2015 Report Share Posted May 2, 2015 Well amp questions are for the amp section. I'll move it THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Do-LowHrzHurts Posted May 3, 2015 Author Report Share Posted May 3, 2015 Well amp questions are for the amp section. I'll move it thank you I'm still getting familiar with this forum format as its very populated with info. Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted May 3, 2015 Report Share Posted May 3, 2015 I would not turn the gain 80% of the way up. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Do-LowHrzHurts Posted May 3, 2015 Author Report Share Posted May 3, 2015 Anyone know of any good downloads for test tones in the 40hz range? Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate Link to comment Share on other sites More sharing options...
Do-LowHrzHurts Posted May 3, 2015 Author Report Share Posted May 3, 2015 I would not turn the gain 80% of the way up. I would like to push it a bit. If it does 750ish rms I will use it on a jlaudio 13w6v2 for the hell of it. The box banged with a polk audio momo 500.1 and it did 550ish Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate Link to comment Share on other sites More sharing options...
