FIRST INSTALL ever. 2012 SIERRA DENALI
I would definintly sand the paint down better and those connectors you have should have been soldered.
XS Battery. Go to there web site and use there program to help find the Battery you need for your YR, make & model.
Very good i will check out xs. As fir soldering I do have some dB link 0 gauge screw ring terminals (gold) I could throw on no?
dont worry about soldering the lugs. It's a nice insurance, yes, but a good solid crimp will do just fine. I run tests at work where I need over 1000amps, often through only one or two 2/0 cables, and every single lug is crimped on. Bad crimps will cause problems though so make sure you have a nice crimper.
Headlights can be a pain in the ass. The battery might not help a ton because the difference in power supply voltage. The alt is at 14.4v and the battery is at 12.8v. so you have a voltage drop of 1.6 until the battery alt alternator are working together 100%. but a good battery will help the voltage from dropping further. I've had improvements from adding a wire from the battery to the car's fuse box and adding a decent sized cap next to each headlight. I forget the value but it was maybe 2/3 the size of a roll of quarters. and then there are HIDs. those wont dim on you.
Lets see how many more people talk about your ground lol.
