Integra_boomer Posted May 9, 2015 Report Posted May 9, 2015 I have a 2000 gmc sonoma ext cab. basically an (s10) anyways i will be running (2) 15" hdc3s on one aq3500.1 i was wondering which setup would be loudest musically subs up port up, subs fired forward port up etc. or should i wall it? kinda stuck on ideas bc to stay under the window line and get the cubic feet i need i will have to put the batteries, amp, etc in the back of bed like in a tool box. was wondering if theres anything you s10 guys have found that works. 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
SMF93 Posted May 24, 2015 Report Posted May 24, 2015 If you have the 3rd fold down seat you can sit the battery in there thats what my cousin did with his extended cab s10, can also build a false floor for the amps
Integra_boomer Posted July 2, 2015 Author Report Posted July 2, 2015 Problem is i have two hdc3 15s and they recommend 4.5 cubes each. If i stay under window line i have a max of 9-10 cubes.. and i want to keep all my amps and batts in the cab. Its looking like that wont happen unless i put my power plant in a toolbox in the bed. Either that or do a wall and configure all my power under the wall in a compartment somehow. Any ideas? 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
catch 22 Posted July 2, 2015 Report Posted July 2, 2015 I also been thinking bout this. I have a 97 s10 ex cab with a single 15 on 3k. I want to add another 15 but want to keep batts and amps in the cab. I honestly don't think there will be enough room unless you walk it
graham0599 Posted July 2, 2015 Report Posted July 2, 2015 Personally in the Dakota club cab I had, I did subs forward port up. 2 Kicker L7 15" on audiopipe 3k did 147.1db My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
OldsBoomer Posted July 2, 2015 Report Posted July 2, 2015 150 with the windows down. sounded great Suburban Coming Soon
Integra_boomer Posted July 3, 2015 Author Report Posted July 3, 2015 I figure the just two 15s in a wall i would still have the room to make a compartment under the wall for amps and batts. the tricks just making it accessable. 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
OldsBoomer Posted July 9, 2015 Report Posted July 9, 2015 accessible without removing the seats or having the third door wont happen. Suburban Coming Soon
catch 22 Posted July 9, 2015 Report Posted July 9, 2015 Agreed^^ these trucks really don't have much room. They're easy to get loud though. Have you thought about some beefy 12s?
Integra_boomer Posted August 3, 2015 Author Report Posted August 3, 2015 Yes but i already have these 15s 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
