Black Beauty Project Build - 06 Ford F-250 Super Duty **1/27/18 - New pics starting on page 41**
Now lets get started with the build.  I'm going to go in the order that it happened.  Just like it happened.  So hang on to your seats.  Won't all get posted tonight but I'll see how far I can get tonight.
I'm going to start with some enclosure design pics.
28154965789_524bff2af8_h.jpgfullsizeoutput_12 by Scott Carver, on Flickr
39935073771_463a60b4e5_b.jpgfullsizeoutput_1e by Scott Carver, on Flickr
28154965699_99c91996e0_h.jpgfullsizeoutput_15 by Scott Carver, on Flickr
39935073701_3c467b70d9_b.jpgfullsizeoutput_1a by Scott Carver, on Flickr
39902528042_3bcf5cbef8_b.jpgfullsizeoutput_19 by Scott Carver, on Flickr
26062589988_8f1ce6ddbc_h.jpgfullsizeoutput_1c by Scott Carver, on Flickr
28154965619_db7fd32334_b.jpgfullsizeoutput_16 by Scott Carver, on Flickr
And for those that want to know about the numbers, here you go.
39935073811_bfc9dfc5a0_b.jpgfullsizeoutput_10 by Scott Carver, on Flickr
I also have a design for a 4th order, but I'll hold on to that.  I'm going to stick with the 6th order for now, the numbers on the charts look better and seems like this would do much better musical, which is what I'm after.  This is not a competition deal, it's a musical, daily driver, bass for an hour commute each way, demo at shows when I go deal.  There may be a point in time where I switch to the 4th order just to say I built it and see what the differences are.  But that won't be for a while.  I'm very interested to see what it does with port changes and playing around with it like that.  Ok enough of that, moving on.
I got started with A LOT of wood cutting.  I did do some videos of it all, but they're seriously raw.  So I'll just stick to the pics.
28154973329_717ed8b21d_k.jpgIMG_0561 by Scott Carver, on Flickr
28154973429_1a4519c163_k.jpgIMG_0562 by Scott Carver, on Flickr
I'm pretty good with plans, I was in construction so I can read a set of blueprints, but when you have this many pieces, it's best to label everything.
26062594358_998804c4ab_k.jpgIMG_0563 by Scott Carver, on Flickr
28154973579_e01e0c24a0_k.jpgIMG_0564 by Scott Carver, on Flickr
Lots of port pieces, hmmmm.  Wonder why that is?
26062594488_9b123325a3_k.jpgIMG_0565 by Scott Carver, on Flickr
28154973729_2da8a5b013_k.jpgIMG_0566 by Scott Carver, on Flickr
This was my make shift work area.  Made it so much easier to cut the sheets and have a work station as well.
26062594588_2712e94262_k.jpgIMG_0589 by Scott Carver, on Flickr
Plus I cut in a router table as well.
28154973799_e4be568b97_k.jpgIMG_0590 by Scott Carver, on Flickr
That router table sure comes in handy for things like this!  Now you see why I had so many port pieces.
25063431687_cb8166acec_k.jpgIMG_0591 by Scott Carver, on Flickr
28154973909_4eaf059021_k.jpgIMG_0592 by Scott Carver, on Flickr
26062594808_8ce8bce11a_k.jpgIMG_0593 by Scott Carver, on Flickr
25063431857_eb7550c2c4_k.jpgIMG_0594 by Scott Carver, on Flickr
This took some time!!
25063431917_523bf70701_k.jpgIMG_0595 by Scott Carver, on Flickr
26062595048_3c33c17b7e_k.jpgIMG_0596 by Scott Carver, on Flickr
25063431957_0eaf8f0cf7_k.jpgIMG_0597 by Scott Carver, on Flickr
28154974419_6f6843a925_k.jpgIMG_0604 by Scott Carver, on Flickr
25063432057_c32a1ea56c_k.jpgIMG_0605 by Scott Carver, on Flickr
25063432147_4f77fc0f36_k.jpgIMG_0607 by Scott Carver, on Flickr
25063432267_b86f5f45cb_k.jpgIMG_0608 by Scott Carver, on Flickr
26062595528_92b2f739a8_k.jpgIMG_0609 by Scott Carver, on Flickr
I'm actually going to call that it for tonight.  I'll get back at it in the morning.  Good night all.
3 hours ago, Kyblack76 said:
Truck looked fucking rad the last time I saw it also man....... I like where this is goin ....
Thanks!  This was all trying to get ready for the last Sky High BBQ.  It was an adventure that's for sure.
So let's continue on to the actual enclosure building, which was also an adventure.  Not because it was too much for me, but my saw I think wasn't as square as I thought it was. So I didn't have 100% true pieces.  But I didn't notice that until I started putting it together.  But it's a good saw, portable, and I quite frankly don't have the budget for the large shop saws and big fences etc.  So, I do with what I have.  Maybe if I decide to do it over again, or the 4th order, I'll go back to my tried and true skill method of the circular saw and a clamp fence.
Here we go!
25063432377_c61facf9dd_k.jpgIMG_0001 by Scott Carver, on Flickr
No I don't know how you guys feel about your glues, I've never been one to really understand them and the different kinds, but I did a little research on this Titebond III.  I usually use the Titebond II but this says it's a bit more water resistant than the others.  With this being originally an exposed enclosure build, I didn't have any type of bed cover for the truck bed, I wanted to make sure I had some protection.  I was also planning to bed line the whole thing.
26062595658_84fcd9f9f8_k.jpgIMG_0002 by Scott Carver, on Flickr
Every wall on this enclosure is double layered, with exception of the baffle and it's a triple layer.  Every layer got glued heavily, and screwed about every 4-6" to hold it together.  This actually comes back to bite me in the ass later on but it's just detail stuff.  28154974949_0d0e48a633_k.jpgIMG_0003 by Scott Carver, on Flickr
25063432497_9adb5d971f_k.jpgIMG_0004 by Scott Carver, on Flickr
26062595848_be47168b59_k.jpgIMG_0005 by Scott Carver, on Flickr
25063432817_1d846cd68d_k.jpgIMG_0006 by Scott Carver, on Flickr
26062596268_2d2d70ddbd_k.jpgIMG_0007 by Scott Carver, on Flickr
28154975349_0bd903058e_k.jpgIMG_0008 by Scott Carver, on Flickr
26062596488_9b4574a1f4_k.jpgIMG_0009 by Scott Carver, on Flickr
26062596458_c16398ccae_k.jpgIMG_0010 by Scott Carver, on Flickr
The Jasper Jig and this Ryobi plunge router might be the best investment I've ever made.  Makes life so much easier.
28154975509_31d28e3526_k.jpgIMG_0011 by Scott Carver, on Flickr
28154975649_b0a9c57172_k.jpgIMG_0621 by Scott Carver, on Flickr
I started testing for bolt holes here, seeing where the counter sinking was at and how much meat I was going to have for the bolts and inserts.
26062596728_0a0b0c4f4b_k.jpgIMG_0623 by Scott Carver, on Flickr
This is the test.  Also looking at the closeness of the surround etc.
26062596858_08ab42738c_k.jpgIMG_0624 by Scott Carver, on Flickr
As  you can see, not much there.
26062596908_82b669bc9c_k.jpgIMG_0625 by Scott Carver, on Flickr
And in some cases, it actually pushed the plies out when I drilled the holes.  I wasn't going to leave that there, in case any one was wondering.  They all got sanded and cleaned up.  I didn't want to take any chances.
25063433357_7404914b89_k.jpgIMG_0626 by Scott Carver, on Flickr
All of the layers glued and screwed together.
25063433447_83436e80c6_k.jpgIMG_0012 by Scott Carver, on Flickr
The top had to be done in two sections.  The larger section is for the larger chamber and the smaller section obviously for the smaller chamber.  Unfortunately they don't make 5' by 8' Pieces or this would've been one piece.  LOL
25063433537_736d00948b_k.jpgIMG_0013 by Scott Carver, on Flickr
Sub baffle.
25063433607_af9a9458ca_k.jpgIMG_0014 by Scott Carver, on Flickr
25063433677_92fd263a32_k.jpgIMG_0015 by Scott Carver, on Flickr
Then I started putting it together.  So if you notice, every wall's inner piece is smaller by 3/4" than the outer piece.  This was for strength when finished.  Kind of locking in place type of thought.
25063433717_1f4c06c1e6_k.jpgIMG_0016 by Scott Carver, on Flickr
The other thing is, this is not birch.  This is $25 a sheet cabinet ply from Home Depot.  Knowing I was going to have to use about 9 sheets for this, I was all about saving money.  However, the draw back is the weight.  Not as heavy as MDF, but not as light as birch.  Somewhere in the middle. So flipping it and moving it was kind of a pain.
25063433767_0a4f918419_k.jpgIMG_0017 by Scott Carver, on Flickr
25063433817_aa6522bc94_k.jpgIMG_0018 by Scott Carver, on Flickr
26062597608_17ae245be5_k.jpgIMG_0019 by Scott Carver, on Flickr
25063433897_b349f1216a_k.jpgIMG_0020 by Scott Carver, on Flickr
39224354984_8bc3269148_k.jpgIMG_0021 by Scott Carver, on Flickr
25063433977_53c2652a84_k.jpgIMG_0022 by Scott Carver, on Flickr
In these pics you can kind of see a problem with one of the walls.  I'm not sure what happened, if I miss measured, or what, but one inner wall is about 1/4" taller than the rest.
25063434057_9cb82eedee_k.jpgIMG_0024 by Scott Carver, on Flickr
26062597798_fa0c3a54c7_k.jpgIMG_0025 by Scott Carver, on Flickr
So in order to fix that I had to get creative again. Adventures!!
28154977419_4e7cf82b1b_k.jpgIMG_0678 by Scott Carver, on Flickr
26062598048_338b07d45f_k.jpgIMG_0680 by Scott Carver, on Flickr
25063434417_c6bb8fbab4_k.jpgIMG_0682 by Scott Carver, on Flickr
28154977499_40c270c90d_k.jpgIMG_0683 by Scott Carver, on Flickr
and boom, it worked!
26062598158_7476b0dfdd_k.jpgIMG_0684 by Scott Carver, on Flickr
26062598198_a53ed65dac_k.jpgIMG_0685 by Scott Carver, on Flickr
This is what I meant by things not squaring up.  Really is a pain in the ass. I'll fix it all eventually, but for now it'll just be ugly.
28154977729_9187ee9aab_k.jpgIMG_0686 by Scott Carver, on Flickr
Tops aren't screwed down, that's why the edges are bowed a little bit.  In case anyone noticed.
25063434647_ad2892545b_k.jpgIMG_0687 by Scott Carver, on Flickr
Here's where I wanted to take this to another level.  I had originally thought about how I was going to do the inside, and I was going to just paint it or something simple. Problem is, that's not my style. So I got to thinking about what I could do, and actually I did this a while ago in the design stage because I had to think about air space loss etc.  But here's where I change the looks of this enclosure a bit.
Let's get creative.  A long time ago, like 4 years ago, when I moved into my house we had to remodel a room in our house because we had a roof leak.  Well when we did that we went back with a wood flooring.  I happened to have a case of it left over.  Take a look.
26062598298_5822aaf580_k.jpgIMG_0690 by Scott Carver, on Flickr
26062598388_6905c0382f_k.jpgIMG_0691 by Scott Carver, on Flickr
26062598458_c3a1298d8e_k.jpgIMG_0719 by Scott Carver, on Flickr
25063434877_757388b8db_k.jpgIMG_0873 by Scott Carver, on Flickr
28154978279_a77e7ce9a6_k.jpgIMG_0875 by Scott Carver, on Flickr
26062598688_4d195b1176_k.jpgIMG_0879 by Scott Carver, on Flickr
25063435047_486f3482bc_k.jpgIMG_0880 by Scott Carver, on Flickr
25063435077_fbb4f16779_k.jpgIMG_0881 by Scott Carver, on Flickr
25063435367_2e2d3d9846_k.jpgIMG_0882 by Scott Carver, on Flickr
28154978749_fb7a3fc00e_k.jpgIMG_0883 by Scott Carver, on Flickr
25063435237_3ed35a610f_k.jpgIMG_0884 by Scott Carver, on Flickr
25063435337_e70c88d84f_k.jpgIMG_0886 by Scott Carver, on Flickr
26062599098_d896aaed23_k.jpgIMG_0888 by Scott Carver, on Flickr
25063435427_8e4da44d38_k.jpgIMG_0889 by Scott Carver, on Flickr
25063435487_4b2116fe55_k.jpgIMG_0891 by Scott Carver, on Flickr
26062599288_ae8acd1d37_k.jpgIMG_0890 by Scott Carver, on Flickr
25063435807_bba35ebe12_k.jpgIMG_0894 by Scott Carver, on Flickr
25063435577_cd4e1452e9_k.jpgIMG_0896 by Scott Carver, on Flickr
26062599588_d9337f81a0_k.jpgIMG_0898 by Scott Carver, on Flickr
28154979559_c47ddef203_k.jpgIMG_0900 by Scott Carver, on Flickr
28154979679_ccf9c06e8e_k.jpgIMG_0913 by Scott Carver, on Flickr
