ZAPCO209 Posted May 22, 2015 Report Posted May 22, 2015 After searching the forum i found a few designs for two american bass xfl 12s but none fit my aplication, max dim. 15 height, 35width, 24 depth if possible smaller on width and height. Would like like tunning in mid 30s. Will be sealed off trunk firing into cabin on an ampere 2k. Thanks in advance. THE DRIVING FORCE
boom50cal Posted May 22, 2015 Report Posted May 22, 2015 what vehicle? On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
ZAPCO209 Posted May 22, 2015 Author Report Posted May 22, 2015 its my buddies 2013 hundai elantra THE DRIVING FORCE
bighossf150 Posted May 22, 2015 Report Posted May 22, 2015 you need to be at 4.5-5 cubes after displacement with 16ish sq in of port Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
ZAPCO209 Posted May 22, 2015 Author Report Posted May 22, 2015 hopefully joe x will chime in with a cut sheet cuz im kinda dumb @ box designs THE DRIVING FORCE
Joe X Posted May 22, 2015 Report Posted May 22, 2015 Your box is on the smallish side with your dimensions, if you have more space available let me know, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/4", figure is just an assembly guide, bracing is 1 1/2" wooden dowel rods.NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
ZAPCO209 Posted May 22, 2015 Author Report Posted May 22, 2015 Unfortunately thats the max dimensions thanks for the help I appreciate it. THE DRIVING FORCE
