Sundown Audio X12 Enclosure
So with me running the X12 what would you recommend? as far as box size and port size as well as type of port. kinda sad this box sounds better with the port plugged then unplugged tried that last night out of boredom and it hit a lot deeper sealed.. I just bought a sheet of 1" mdf wood 4' x 8' so I'm looking for a box design to build would like to be tuned around 28-32hertz but I don't have the biggest trunk. was 38" wide X 30" deep for trunk size (that leaves me room for components) . I went onto the sundown audio site and looked at the box specs they have and did some research, ppl that built a box to them specs said the sub sounded bad in that box.
2007 Chevy Equinox
Pioneer AVH-X5800BHS
Big 3
2 runs of 2/0 Welding cable
2 - XS Power D3400 Batteries in Parallel - Fused at 250A
Alpine MRP-2000D - Temp amp.
1 - ZV4 15" Rev 1
I am not super familiar with port area, but that should be more than enough for a single 12. And that thing is tuned pretty high for what you want. As well, it has a lot of port area, so you probably can't go too much lower than your tuning.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Sealed plays close to flat inside a vehicle, how did you like the sound?
Sounded pretty good, was deeper then with the port open. it was at 2am so I didn't have it full blast so didn't get to test it fully, but from what I could tell sealed sounded deeper and cleaner. When I did that I also noticed air coming from the dust cap in the front where the Sundown audio is painted on which pissed me off. So not sure if using it with the port sealed loosened the glue on the dust cap allowing a little air to come through or not either way I'll have to fix that cause just knowing its doing that will bug me. I was never a fan of sealed boxes cause of the simple fact I always had something go wrong when using one and this time was my dust cap leaking air... I am just trying to get ideas for a box that will give me the best sound this sub can produce without having to build a bunch of boxes to test it out. Watched a lot of videos read a lot of reviews everyone has different boxes for this sub and no one ever posted specs of their boxes. I really dislike the current prefab box I have cause its junk and this sub is tearing it apart so I have to build one that is more reliable.
2007 Chevy Equinox
Big 3
1 - ZV4 15" Rev 1
You could try to extend the port from the outside with some cardboard to try some tuning options before deciding on a final spec to build, would be a pretty long port though.
  • 4 weeks later...
I tried a few things wasn't much of a change, I gave up on the box for a single x12 cause im ordering another x12 so now I need to look into a box for two 12s
2007 Chevy Equinox
Big 3
1 - ZV4 15" Rev 1
  • Who's Online   0 Members, 0 Anonymous, 283 Guests (See full list)
