BigManAC Posted July 9, 2015 Author Report Posted July 9, 2015 My friend let me borrow his little 2ch amp today to test out. I installed it the exact same way I did the S800.4 and I had no noise at all. It must be the amp. Everything was the same between the two amps and one had noise while the other did not. Thank you everyone for your help with this. I also took pictures of the wiring just incase you still wanted to see that. Driver side: Passenger side: Im still figuring out where to mount the fuses so the leads going to the amps are not in this picture 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
reedal Posted July 9, 2015 Report Posted July 9, 2015 Glad it's figured out. I think Karkov had the same issue with his. Something about that amp. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
lightfoot Posted July 9, 2015 Report Posted July 9, 2015 Doesn't make sense that it would be the amp. If you used your i pod as a source and you did not have noise, then it has to be something in the signal, either your headunit or your RCAs
BigManAC Posted July 9, 2015 Author Report Posted July 9, 2015 Doesn't make sense that it would be the amp. If you used your i pod as a source and you did not have noise, then it has to be something in the signal, either your headunit or your RCAs Thats what I thought too. Side Show suggesting using both inputs when I used the ipod instead of just one set and when I did the noise came back. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
BigManAC Posted July 9, 2015 Author Report Posted July 9, 2015 Glad it's figured out. I think Karkov had the same issue with his. Something about that amp. Yeah I messaged him a while back and he said he was having the exact same problem. Im sending it in to get repaired but if it comes back with the same problem then I guess Ill just have to take a loss 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
BigManAC Posted July 14, 2015 Author Report Posted July 14, 2015 Everything is wired up in the back and I found a place for the fuses. When I turned everything on there was no noise from the amp except in channel 2. Did not change with the rpms just a constant noise/static. Just waiting for DroppinHz to email me back once Cody is done with the move. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
BigManAC Posted July 18, 2015 Author Report Posted July 18, 2015 Crescendo emailed me today and I'm sending the amp in on Monday to have it looked at and fixed. Channel 2 on the amp is where I am getting all of my noise from. As soon as I disconnect the speaker that is in Channel 2 the noise stops. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
99GPGTX Posted September 14, 2015 Report Posted September 14, 2015 Well fk...having simular issues with my 800.4. Gunna trouble shoot this weekend. I have floor hiss and engine wine Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
BigManAC Posted September 14, 2015 Author Report Posted September 14, 2015 Well fk...having simular issues with my 800.4. Gunna trouble shoot this weekend. I have floor hiss and engine wine Yeah there seem to be multiple people having the same issue with the amp. I sent the amp into Crescendo but still haven't heard anything from them. Hopefully I will soon. Hope you figure out your issue man. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
99GPGTX Posted September 15, 2015 Report Posted September 15, 2015 Thanks man...picked it up used. sooo my guess is he had the same issue. :/ Currently: 2015 Evo X WW Forgestar F14 18s --Rally Armour Mudflaps ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers Build: Crescendo Mezzos x2 Crescendo 800.4, 1500.1 Loaded Fi Q12 Second Skin Pro XS D5100 RF 360.2 Sky High Audio Wiring Need: ALTERNATOR! PREVIOUS 1999 Grand Prix GTX 3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded 12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids: Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit: knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400 TEAM DEADLY HERTZ!! Financial Consultant- Charles Schwab
