MrSkippyJ Posted June 18, 2015 Report Posted June 18, 2015 OP, are you just wanting to disconnect your front battery while you work on the install? Unless both batteries are of diff types... then what? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
islandpride684 Posted June 18, 2015 Report Posted June 18, 2015 OP, are you just wanting to disconnect your front battery while you work on the install? Unless both batteries are of diff types...then what? I'm assuming he has an agm in the rear and a stock one up front, based on that an isolator is needed to separate the 2 for charging purposes... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
MrSkippyJ Posted June 18, 2015 Report Posted June 18, 2015 you can safely use both types together without an isolator. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
islandpride684 Posted June 18, 2015 Report Posted June 18, 2015 you can safely use both types together without an isolator. You can but the question is how long will the weaker battery drain the good one...stock<agm Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Jessica Posted June 18, 2015 Report Posted June 18, 2015 its not a boat, and why spend 80 on a isolator and then more on extra terminals and time installing it when you can just get a cheap agm for the front? Remy has sales all the time, ive seen the deka's as low as 90$ Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
JAYCEE3RD Posted June 18, 2015 Author Report Posted June 18, 2015 Sorry guys just got back home. The batteries are different I have a XS power d3400 in the front and a stinger spp2250 for the rear. The rear hasn't been installed yet, I'm still working on everything else to be installed, money has been my issue due to job lost, but, will be back on my feet shortly to get everything finished. JC3rd
reedal Posted June 18, 2015 Report Posted June 18, 2015 No need for an isolator unless you want to play for a long time with the vehicle off, in which case, do so at your own risk because the lower voltage may damage your equipment after a period of time SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
